Legal (A3) flatbed scanner recommendation please
2005-05-30 by frankg_photo
I need to scan Black & White screened images from a 1920's photo book
on the middle east. The original plates were large format and well
reproduced. I need a scanner with a very good dmax and it should be
larger than regular 8.5x11 (A4) size. Is there a particular model that
is recommended and not too 'over the top'expensive ?
thanks
Frank
Re: [Digital BW] Legal (A3) flatbed scanner recommendation please
2005-05-30 by Ernst Dinkla
>thanks
>Frank
You could check one of the Epson XL models, new or secondhand. There's
not much dynamic range needed for scanning reflective originals. If you
have the original glass plates and need to scan them it is a different
story. I would be more worried about the screening if that has to be
taken out.
My Agfa Horizon Plus would be suited for this job too. It scans truly
monochrome in one pass at 1200 PPI. There are newer versions of that A3
size scanner you can find secondhand. 2400 PPI as well. Agfa has no
repair service worth mentioning so you are on your own when it doesn't
work correct. If the prints in the book are perfect, without mildew etc
then monochrome is the best way to go. If there are spots with different
color, discoloration et the edges then color scanning is better as it is
easier to retouch the scans afterwards. The one pass Epson models will
be better then.
Ernst
Re: Legal (A3) flatbed scanner recommendation please
2005-05-30 by Historic Photo Archive
I was in this dilemma and I bought a used Umax Mirage IISE off ebay.  The
seller did not pack it well, didn't lock the carriages, so it was wrecked in
shipment.  However it seems he had a whole pallet load of them, and sent me
another which was better packed, it worked fine after cleaning.  Now I have
a parts unit too.  Bid was $75, shipping $40.
I tried the Mustek, it was so bad I threw it away.  Absolutely unuseable.
I was thinking of a new Microtek, i have an Artixscan already and it is
decent.  Factory support is non-existent for out of warranty units, after 12
months your only option is to exchange for about half of list price plus
shipping.  They will not sell parts and they will not repair.
In a way, I am glad that I had to learn how to fix my own scanner.  The
image has to go through two glass surfaces and three mirrors before it gets
to the lens.  Over a relatively short period of time these get dirty, you
can look into your scanner and probably see the haze forming on the glass.
I dismantled my Artixscan to fix the problem, a line in scan, caused by dirt
on mirror in the carriage.  I used tissue and denatured alcohol for cleaning
the mirrors, this is what I was told to do by an expert camera repairman and
is how he cleans mirrors on SLR cameras.
So when i got the Umax A3 I took it apart and completely cleaned everything.
It is SCSI, so I bought an old G3 for $50 to drive it, and put on an old
version of Vuescan.  For $115, it is the best bang for the buck, I saved
thousands of dollars compared to buying a Microtek or Epson.  I hear that
Epson has stopped support of non-warranty scanners but I don't know.  I
don't think there is any value in buying a new scanner, the warranty is only
12 months, so if it breaks on its 14th month, like mine did, you are
screwed.  I'll do a little extra work and keep the savings.  You have to
learn to maintain the scanner anyway, no matter what you buy.
Thomas Robinson
http://www.historicphotoarchive.com
2005-05-30 by deanwork2003
We've had very good results with the larger and smaller Microtek and Epson
flatbeds where I teach, and they get abused a lot. I'm sorry I don't know the
model numbers. My brother had a new Umax that gave him nightmares,
exchanged it for another one after months of poor support, and it was bad too.
He finally got his money back and bought an Epson and has had nothing but
good results with it, as I have with my smaller Epson that just keeps on ticking
after 5 years. I got my money back on that thing in 2 months. The hard thing to
know about buying a used scanner is if anyone has dropped it. That is always
a gamble with Ebay and scanners or digital cameras.
John
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Historic Photo
me
everything.
> Thomas Robinson
2005-05-30 by Djon
There are some incredible sub-$200 bargains in refurbs from Epson
direct...that's where I got my 3200 a couple of years ago, saving big
money...
As to cleaning them...alcohol is a *terrible idea* as most types of
alcohol leave deposits. I like Windex Glass and Surface Wipes (each
sealed in a package, very wasteful but very effective)though regular
Windex reportedly leaves a film.
The best way to take care of flatbeds is to keep your hands off the
surface and keep the scanner under a dust cover...if you do that, and
if you don't keep the scanner in a dirty environment, and if you don't
smoke around it, you virtually never have to clean.
Djon
keeps on ticking
> after 5 years.
> John
