Hi Jean,
I'm not as versed as some others about the required maintenance
signal, but can tell you that
the cartridge block can easily be moved to the left, along the track,
by first turning off the 2400,
then turning it back on. When the cartridges start to move to the
left as part of the initial
startup, pull the power plug from the wall and leave the power switch
on. You will now be
able to freely move the cartridges back and forth. This is the method
I've use many times to
clean the bottom of the carts with soft paper toweling soaked with
Windex solution.
Hope this helps.
Clay Price
Jean Verrept <j.verrept@...> wrote:
> I managed to block my Epson R2400. After I changed a MP for a PK I
printed
> two sheets and then the cartridge block came to a standstill, two
red lights
> flickering. I guess the cartridge is to blame but I can¹t get it out.
> Question, how do I move the cartridge block to the left manually.
There
> should be a catch somewhere but I don¹t see or feel it.
