Raw conversion and B&W
2005-06-01 by Stephen Kobrin
Is there any point in working with the color temperature and tint
sliders in Adobe Raw if the image is ultimately going to be converted
to monochrome?  Intuitively, it seems that the color balance should
affect the tonal range as it affects each of the R, B and G channels
differently.  However, that is no more than an uneducated guess.
As an aside, I have just started experimenting with a new Canon Rebel
XT with the EFS 17-85 lens.  While I have a lot to learn, it is clear
that the image stabilization really does work well.  I have shot at the
85mm end of the zoom (135mm in 35mm terms) at a 30th with reasonable
results.
Steve
Re: Raw conversion and B&W
2005-06-01 by Djon
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen Kobrin"
Try it and see. I will...though I won't convert to monochrome to get
my B&W... I never convert to monochrome when I'm printing B&W from
color (using QTRgui). There seems no reason to convert, since I use a
traditional Zone System frame of reference (ie the real world is seen
in color when you shoot B&W film...I visualize B&W from real-world
color just as I do when I see color on a monitor and print B&W).
Djon
> results.
This is very interesting. When you say "reasonable," do you mean "as
good as shooting at 1/100? (ie do you gain two steps, the shutter
equiv of 2 full f-stops?).
> Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Djon"
a
seen
> Djon
Djon,  I am not sure that I understand your comment.
Yes, to my naked and unprofessional eye.  Canon claims you can gain
three stops, but I have not tied.
Re: [Digital BW] Re: Raw conversion and B&W
2005-06-01 by Steve Kale
A pity as you miss out on the opportunity to adjust post capture the light
balance - equivalent to using a filter at capture. As for the Zone system,
it is not really very relevant in today's digital world where one can
determine mid-grey and clipping points (if any) post capture.
> From: Djon <westsidemaurice@...>
> Djon
2005-06-01 by Djon
> seen
> > Djon
The world is full color. Employing the most basic Zone System, one
envisions the finished B&W print from that color (only incidentally
the negative) before exposure.
Assuming Zone System experience, it's easy to visualize B&W prints
directly from color TIFFs, adjusting contrast and other factors in
color via Photoshop and then printing with QTRgui...
I know no technical or visual reason to convert to monochrome...
monochrome conversion apparently confuses the issue (evident
repeatedly on this forum), causing obsession with monitors rather than
prints.
 stabalization:
This means an f4 lens is equivalent to a 1.4 lens, but with far
greater depth of field! Sign me up! (though it's sayonara to "bokeh").
Djon
2005-06-01 by Djon
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
<stevekale@b...> wrote: As for the Zone system,
Steve, If one is more a photographer (Vs print maker) one MAY want to
determine as much as possible in the field or studio, rather than
hunched over a computer.
"Photographer" has something to do with brief instants, whereas "print
maker" has to do with extended processes...they are not one in the
same and do not need to co-exist (there are many fine printers and
many fine photographers who do only one part of this continuum well).
Comprehensive post-capture adjustments for B&W printing from color
files do not require monochrome conversion in any case.
Zone System skills come in two flavors: 1) geek flavor (quantitative)
2) sensory flavor (visualization). For obvious reasons, some
traditional printmakers cling more to the geek side. Interestingly,
these two flavors/sides correspond to easily measured personality
characteristics and to thoroughly-documented characteristics of each
of our two brain halves.
For pleasure (the point of photography for me) I engage the
artist/visualization side of photography and of my brain as much as
possible, just as most of us always did with film, just as musicians
and athletes always do. Happily the technology makes the geek aspect
relatively simple, just as it is in tradional wet darkroom work.
To assert that previsualization (that side of Zone System) is "no
longer relevant in today's digital world" is literally to say that one
side of our brain is no longer relevant!
Djon (R2D2? HAL?)
> > From: Djon <westsidemaurice@y...>
> > Djon
2005-06-01 by Clayton Jones
Hello Steve,
>converted to monochrome?  Intuitively, it seems that the color
>balance should affect the tonal range as it affects each of the
>R, B and G channels differently.  However, that is no more than
I've found that altering the colors _can_ affect the resulting BW
shades, but to what degree depends a lot on your BW conversion
technique.  But in general, if you do things like intensify a blue sky
you can end up with a darker gray sky.  Also, if there are any colors
that typically convert to middle gray, such as peach or salmon, these
can also be adjusted to affect the final tones.
Also, a lot depends on the individual image and what things you might
want to emphasize, so the approach may vary from one to another.  For
example, suppose you do a portrait of a woman who is wearing red
lipstick.  You may wish to emphasize or deemphasize that, and act
accordingly.
So you really need to experiment with whatever BW converson technique
you use and different ways of manipulating colors, to determine what
works for you.  There are countless combinations and you will evolve
your own style.  Experience over time counts heavily here.  It's worth
the effort, though, because often you can influence an image easier
while it's in color than later in BW where you'd have to make some
time consuming selections, etc.
Clayton
Thanks Clayton.
Steve
<cj@c...> wrote:
> Hello Steve,
sky
colors
these
might
For
> accordingly.
technique
worth
> Regards,
> Clayton
Firstly I did not assert that pre-visualisation was no longer relevant.
Secondly, the Zone system has nothing to do with black and white per se - it
is merely a system for determining appropriate exposure when such exposure
can not be significantly "altered" post shutter release.  All the Zone
system does is provide a rigorous framework for determining middle exposure
and an understanding as to how the rest of the elements will be exposed as a
result.  B&W is merely a simplifying case.  There are many arguments that
support the notion that when capturing with digital one ought to capture the
maximum possible information, even if that results in an exposure different
from one that sets the mid-exposure at a pre-visualised level.  In such
case, you can always produce the pre-visualised result. Alternatively, with
reflection, one can explore, within broader boundaries, new creative
perspectives on the scene.   To be bound to your initial perspective is not
necessarily a good thing.  That is not the same thing as saying that
pre-visualisation and thoughtfulness ahead of image capture are unnecessary
- quite the opposite.  Of course it makes sense to think through the
image/scene as much as possible to a final result.  It simply recognises
that we need not necessarily be bound by it at a later point. Digital
capture and image manipulation opens up new opportunities.  The Zone System
is not Pre-Visualisation.  Don't confuse the two.  The Zone System was
developed to provide a rigorous framework for technically producing the
pre-visualised image.  As the technical tools at hand change it is is not so
strange to suggest that the technical framework be adapted.
> Date: Wed, 01 Jun 2005 15:52:03 -0000
> Subject: [Digital BW] Re: Raw conversion and B&W
> Djon (R2D2? HAL?)
>>> Djon
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the membership
> without notice.
> printing. Users who persistently make off-topic posts may be removed from the
> membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
> Moderators. See ³Group Topic, Rules and Guidelines² in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE ³OWNER² AND
> ³MODERATORS² OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL,
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  ³OWNER² AND ³MODERATORS² OF
> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR
> TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE
> DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE
> DIGITAL BW, THE PRINT YAHOO GROUP.
2005-06-01 by Djon
Steve, there are/were two divergant Zone System tendencies.
One emphasized number assignment, the other emphasized
previsualization. Two sides of the same coin, appeal IMO to two
fundamentally different kinds of personality.
You're right that Zone System doesn't simply mean "previsualization,"
but previsualization is central to it.
Post-processing that's not the result of previsualization is (IMO)
outside Zone System, a matter of manipulation (not a negative IMO).
I happen to resonate more with what I understand, from several of his
students, to be Minor White's angle on Zone System rather than Ansel
Adams'.
I think Minor's angle emphasized previsualization more than Ansel's.
Minor's students were printing masters but they didn't seem very
interested in densitometry and were obviously drawn to strongly
emotional images more than to beautiful rock and water with subtle
tonal scales. Like Weston, a better printer early on than Ansel, Minor
appealed more to sensualists.
From small dealings in the Seventies with Ansel and his students, and
from following his books and later work, it seems to me that he grew
more technically than visually with age, the opposite of Minor's growth.
In Ansel's last (perhaps) book project he focused on quantitative
technical matters (scanning and lithography). This is honorable, an
extension of his angle on the Zone System that he began with Minor White.
Minor, on by contrast, was a Zen practitioner who photographed people,
content, and meaning...a different side of the brain with different
passions, employing a different angle on the Zone System. Ansel was
also a fine people photographer who could make eloquent connections,
but some forget that in their enthusiasm for numbers.
Minor's Zone System game seemed to make the image he wanted to make. I
think Ansel's was more a matter of process for its own sake...workflow.
++++ Photography and printmaking are part of a continuum and that this
is sometimes forgotten by people at the extremes of the continuum.
Djon
se - it
exposure
exposure
exposed as a
> result.
2005-06-01 by guy washburn
Djon,
I certainly place my self in the sensualist camp but I
find it deeply curious to work on b&w prints without
looking/working with b&w files before printing. Unless
you previsualize using the same algorithm that the
QTR/gimp uses, it is unlikely that you will ever get
the exact print you envision. Of course no one but you
knows that so your secret is quite safe. In a way it
is more like the result of wet dark room work where
the fruits of your labors are only seen in the
developer not on the easel where most of the
manipulation occurs -- perhaps this is the attraction,
the role of chance? I don't like the amount of wasted
paper it took to make a wet darkroom print sing. With
softproofing using qtr_matte prints just match. From
raw file score to symphony finished print with more
control than we ever had in a wet darkroom (though we
wave our arms less now). Does an inkjet print have
Buddha nature? It does if the artist has skillfully
presented his vision and  shares it's meaning.
Peace,
Guy
> tendencies.
> emphasized
> IMO to two
> "previsualization,"
> negative IMO).
> from several of his
> rather than Ansel
> Adams'.
> more than Ansel's.
> didn't seem very
> to strongly
> water with subtle
> than Ansel, Minor
> his students, and
> me that he grew
> quantitative
> is honorable, an
> with different
> System. Ansel was
> numbers.
> wanted to make. I
> the continuum.
> Djon
> Steve Kale
> black and white per
> se - it
> exposure when such
> exposure
> determining middle
> exposure
> elements will be
> exposed as a
> > result.
Yahoo! Mail
Stay connected, organized, and protected. Take the tour:
http://tour.mail.yahoo.com/mailtour.html
2005-06-01 by Djon
Guy, you and I evidently do understand these matters similarly. Ansel
was almost a sensualist too, while young :-)
I certainly do NOT always get "exactly" the print I envision (that's
only theoretically possible to the digitally preoccupied). I don't
think "exact" is a virtue, for that matter. I do reliably get very
close approximations, just as you and I did in the darkroom, and
occasional happy surprises that may less available to people who play
the game the way you now seem to recommend.
Some of us are raku-people
 http://www.alfargaleriaazul.com/eng/cour.htm
Others are Meissen-people http://www.jdweedco.com/china/china5.htm
Djon :-)
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, guy washburn
<guido02474@y...> wrote:
> Djon,
> Peace,
> Guy
> > tendencies.
> > emphasized
> > IMO to two
> > "previsualization,"
> > negative IMO).
> > from several of his
> > rather than Ansel
> > Adams'.
> > more than Ansel's.
> > didn't seem very
> > to strongly
> > water with subtle
> > than Ansel, Minor
> > his students, and
> > me that he grew
> > quantitative
> > is honorable, an
> > with different
> > System. Ansel was
> > numbers.
> > wanted to make. I
> > the continuum.
> > Djon
> > Steve Kale
> > black and white per
> > se - it
> > exposure when such
> > exposure
> > determining middle
> > exposure
> > elements will be
> > exposed as a
> > > result.
> Yahoo! Mail
2005-06-02 by guy washburn
Djon,
Craft is being able to deliver your vision and put it
right there onto that piece of paper. I believe that
the field (or street or studio) is where the happy
accidents should be courted. Those amazing moments
when the light, life and chance collide. Then you
bring that to the light room and put every ounce of
your craft into getting the most out of the print,
shadow detail and highlights right where you want
them. Get past the tools and it is every bit as
passionate as the old ways. Do Raku when you shoot and
Meissen when you process to print. That ravishing
print on the heavy art paper that captures fully the
emotion of what you saw when your heart called you to
make the exposure. What you felt wasn't something to
be left to chance why should it's expression be?
Guy
> similarly. Ansel
> envision (that's
> reliably get very
> darkroom, and
> to people who play
> Djon :-)
> guy washburn
> > Djon,
> but I
> without
> Unless
> get
> you
> it
> where
> attraction,
> wasted
> With
> From
> more
> we
> skillfully
> > Peace,
> > Guy
> > > tendencies.
> > > emphasized
> appeal
> > > IMO to two
> mean
> > > "previsualization,"
> (not a
> > > negative IMO).
> understand,
> > > from several of his
> System
> > > rather than Ansel
> > > Adams'.
> previsualization
> > > more than Ansel's.
> > > didn't seem very
> drawn
> > > to strongly
> > > water with subtle
> early on
> > > than Ansel, Minor
> and
> > > his students, and
> seems to
> > > me that he grew
> focused on
> > > quantitative
> This
> > > is honorable, an
> he
> who
> brain
> > > with different
> Zone
> > > System. Ansel was
> > > numbers.
> image he
> > > wanted to make. I
> its
> of
> > > the continuum.
> > > Djon
> > > --- In
> > > Steve Kale
> pre-visualisation
> with
> > > black and white per
> > > se - it
> > > exposure when such
> > > exposure
> shutter
> for
> > > determining middle
> > > exposure
> > > elements will be
> > > exposed as a
> > > > result.
> > Yahoo! Mail
> tour:
=== message truncated ===
Discover Yahoo!
Find restaurants, movies, travel and more fun for the weekend. Check it out!
http://discover.yahoo.com/weekend.html
2005-06-02 by Djon
> Guy
Guy, we disagree ultimately, but it's been fun: What I "felt" was in
fact blessed by chance, just as life is. Good fortune is commonly
frittered away by excess..too much "considering." Ansel's biggest gift
was not obsessive craftsmanship, it was his courting of chance, his
presence in the mountains at the right times with adequate craft. I
think he'd have been as great if he shot chromes for Arizona Highways
in the Fifties, completely ignoring B&W.
Djon
> > similarly. Ansel
> > envision (that's
> > reliably get very
> > darkroom, and
> > to people who play
Re: [Digital BW] Raw conversion and B&W
2005-06-02 by Mark Rabiner
On 6/1/05 5:45 AM, "Stephen Kobrin" <kobrins@...> typed:
> results.
> Steve
Well sure if you wanted to make it look like you shot it with a say green or
yellow-green filter which is often a good idea anyway (yellow-green restores
a true Panchromaticity to panchromatic films which really are not that
panchromatic after all) you just make it look like you shot it with that
filter.! The way it would look like you were looking at a scene though the
lens of an SLR with that filter on it or just holding the filter in front of
the subject up to your eye.
Then when you convert it to RGB its going to have that filters effect.
Foliage lightened. A nice tone to the sky. But the shadows next to the trees
and rocks not darkened like with a yellow.
I¹m sure that¹s half the reason they have that whole new part of Photoshop
in which emulates various real time real glass for real lenses on real
cameras filters with the Wratten names and everything.
And it¹s about time because  I always found it funny the extended metaphor
they were using with the glass round filters which would come up in the pop
up screen when you first opened Photoshop 2 or 3.
In a metaphysical and moral dilemma they put these filters under Image
-adjustments. Instead of under the Filters menu.
Lets see which filter should I use the YELLOW filter
    or MOSAIC TILES?!?!
The 81a warming filter
    or POINTILLIZE?!?
A RED filter
    or PLASTIC WRAP?!?!
A tungsten correction cooling 80 filter
    or DE INTERLACE!?!
I wonder if I can special order a POINTILLIZE filter from B+W with a multi
coating?
And get it in CUBIST too!
Give me a 52mm ³Nude descending a Staircase² filter with a brass mount!
Mark Rabiner
Photography
Portland Oregon
http://rabinergroup.com/
