Re: [Digital BW] 'Color management' in PS or Advanced B/W driver[Mac, R2400]
2005-06-03 by Sonny Taylor
Yep, just repeated it again with "No Color Management" and the dark 1/4 of the strip is total black! Turn CM on, and the scale is great. Something's wrong???? Thanks, Sonny
> I have not done any test strips but the correct setting is no colour > management in PS CS2 or Same as Source in PS CS. In other words you just > send the file numbers only. > > > > From: Sonny Taylor > > Reply-To: > > Date: Fri, 3 Jun 2005 11:35:42 -0500 (CDT) > > To: > > Cc: , , > > > > Subject: [Digital BW] "Color management" in PS or Advanced B/W > driver [Mac, > > R2400] > > > > I wonder if anyone has any experience with the Advanced B/W driver, with > > respect to color management in PS? I am testing my R2400 and am trying to > > resolve a statement by Jeff Schewe in his excellent article in > PhotoshopNews: > > > > http://photoshopnews.com/2005/05/16/epson-r2400-and-ultrachrome-k3-ink-report/ > > > > where he states: > > > > "Printing out of Photoshop CS2, I used the Print with Preview dialog > to set up > > the Photoshop to Epson driver hand off. Since the Advanced B&W Mode > operates > > completely outside of normal color management parameters, in Photoshop you > > must turn off any color management". > > > > I wonder if I am doing something wrong. I am printing a B/W strip > posterized > > to 31 segments. The first segment is 100% black, the second 97% black, and > so > > on. > > > > Prior to reading Jeff's article, I did my tests with Color Management ON in > PS > > and as I have always done with color; and the results with the Advanced B/W > > driver are excellent, except for some difficulty in differentiating the 100 > > and 97% (they are both black, even though I can see a difference on my > > monitor; with a curve in PS, I can slightly open up the 100-97%). > > > > There is very little change in the shadows using Shadow Tonality in the > > Advanced B/W driver, from -25 to +25. > > > > After reading Jeff's article, I turned off CM, passing control to the > Advanced > > B/W driver. The strips became all black for many more segments. I could not > > open them up using the driver. > > > > Am I missing something from Jeff's article? It seems that CM ON in PS still > > gives much better results than I can achieve by the driver alone. > > > > Is there a better way to open up the deep blacks? > > > > Any comments will be greatly appreciated. > > > > Thanks, > > > > Sonny
