What MIS Said About My UT7 Ink Sytem Problem
2005-06-16 by SteveZ
After hours of frustration and hair pulling, I finally called MIS
tech support to get answers on the UT7 carts that I recently
purchased for my 2200. Although, I had followed Paul Rourke's two
workflows to a "T" (curves and sliders)I still wasn't getting any
near the quality these inks are capable of producing. Instead, my
test prints displayed strong vertical banding and b&w tonality not
of this earth.
I asked MIS for some suggestions. The very first thing they asked me
was "have you removed all of the silver strip on the top of each
cartridge? The ventilation hole MUST be clear otherwise the inks
won't work properly."
And guess what? I hadn't.
I was told I could purchase an expensive syringe to draw the air out
of the cart or let the ink carts sit for an hour or so for the air
to dissipate.
Has anyone else every encountered this problem with this ink system?
I hope the MIS suggestion works because, after hearing about all the
accolades about UT7 inks, I'm eager to start using them.
