Mothballing printers.
2005-06-22 by dlruckus
Hi folks.
This should probably be addressed to Tyler, Ernst or Paul Rourk but
includes all. I will be leaving for as long as a couple of months soon
and have 2 printers I need to care for. The 1st, a 7000, still has dye
inks in it and I will be be pulling those and flushing the printer and
will leave it that way until I can load pigs into it for use.
The other is a 3000 with VM carts. I would rather not transport
prepare it if I can avoid it so am wondering if it would work to leave
it turned on but on a timer that switched power to it for 15-20
minutes a day.
I know that works with the smaller printers as I used the technique on
my old 1200s and it was fine. I don't know if it works in the same way
on the 3000 though.
Any advice would be greatly appreciated.
Duane
Re: Mothballing printers.
2005-06-22 by dfaprinting
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dlruckus"
<dlruckus@y...> wrote:
> Hi folks.
soon
dye
and
leave
> minutes a day.
on
way
> on the 3000 though.
> Regards
> Duane
Why not flush the lines on the 3000 too? Probably cost less ink, and
less of a chance that a power spike can fry it (if you unplug it).
Sounds like an great time to run cleaning fluid through it, so it's
ready to print when you return. That's what I would do if it was mine.
