Flesh tone to shadow transition jagged/ugly. Why?
2005-06-21 by neilsphoto
Here's the deal. I like good side light in my portraits from windows or softboxes. A nice modeling and tonal range into a nice shadow. I tend to bump the contrast to get a nice black, no always a darker black (they only get so black) but maybe more black if that makes sense. Sometimes on the transition from flesh to black it gets jagged looking, ugly and sort of solarized. It is very hard to describe and even if I could post the image here it wouldn't look like it does in print. I've seen it with D2H and D70 files. I upsize them in CS a little at a time to 12x18 ( I rarely see this in a 6x9). I had been set to Bicubic. It has been suggested I use Bicubic Smoother instead. I've had it much less so with scanned TX or XP2. I scan with a Minolta 5400 and my files are much larger than what I get out of camera so upsizing isn't needed. I have been BO printing for over a year. 2200, Ebony and EEM or PR. I thought that maybe I was asking alot of one ink to make a smooth transition so I got UT7. Same, different, I don't know. I get get either ink set to do the same thing. So I get an image I like on screen, make a print and decide to give it a little more snap. I might tweek the brightness/contrast a bit and make another print and then I may get this jagged look it I went too far. I've most likely already done some levels adjustment before the first print already. It clearly looks as if I've put down too much ink. Is this a dot gain issue? I'm at 20%. Would Genuine Fractels be better for up-sizing my D70 files than CS? Or am I just asking for too much. Again it is hard to describe what I'm getting. I could e-mail a sample portrait and describe where the problems lie but you won't see it in a jpeg. Gotta be on paper. Any ideas welcome. Neil
