2400 - Paper issues
2400 - Paper issues
2005-06-26 by wwodets
To continue from my last post:
Having only had previous experience with the 2000P and not using it
seriously as a BW printer, my only previous experience is with the
Epson Watercolor RW.  Because the 2400 immediately struck me as a
serious BW printer, I've explored several other papers.  I'd
appreciate any feedback on both my "flow" process and the papers.
I have a monitor calibrated (with a Pantone Spyder 2) to 5000K and
2.2.  My first prints on the 2400 did not match the monitor, so I
decided to adjust the prints to match the monitor (rather than vice
versa).  On Epson Enhanced matte this required an adjustment in the
ABW driver of: contast +10, brightness +8 and shadows +10.  The
monitor to print match on EEM is very good, the blacks are deep and
excellent and the gray scale is smooth and elegant.
Other papers were variable in their results.  Crane Museo was murky
in the shadows with poor detail and showed "bronzing" at acute
viewing angles and I eliminated this paper (it is also very yellow);
Hahnemuhle Photo rag showed deep blacks but poor shadow detail, the
latter improved by using the Watercolor RW setting in the ABW
driver.  (Contined next post.)
Re: [Digital BW] 2400 - Paper issues
2005-06-26 by Steve Kale
You are better off preparing a proper soft-proof.  Unless the black and
white points are matched via a soft-proof (and all points in between
properly scaled) you will never get a reasonable WYSIWYG - even then there
are so many factors going into the display vs print view that things can
never be fully equalised.  But a proper soft-proof is a more robust starting
point.  A technique using Eye-One Match has been fully discussed on this
forum.
In addition, Roy Harrington has been doing additional work on his greyscale
ICC profiles.  These are about ready for the primetime and can be used to
profile the luminance axis of any workflow.  They will give you a much
better management of the dynamic range compression necessary in going from
your workspace to the dynamic range of printer greyscale.  Keep an eye out
for these - they really do represent an outstanding advance to current B&W
printing workflows.
> From: wwodets <odets@...>
Many thanks--I will heed all advice offered.  Walt
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
and
then there
things can
starting
this
> forum.
greyscale
used to
much
going from
eye out
current B&W
> printing workflows.
> > From: wwodets <odets@c...>
vice
and
Re: 2400 - Paper issues
2005-06-26 by schrochem
Just passing along the icc workflow mentioned here a few months ago.
http://tinyurl.com/7j6um
scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "wwodets"
> greyscale
> > ICC profiles.
2005-06-26 by Scott McLoughlin
As ICC profiles, am I right to presume these could be used with PWP (
and some other apps) as well as PS?  Thanks.
Scott
> greyscale
> printing workflows.
The currently distributed profiles are designed to be used with QTR and can
be used by any colour managed software that can invoke QTR as the printer
driver.  They assume that the greyscale produced has linear L*.  The photo
profile has a lower black point than the matte.  But Roy has some very cool
stuff to come shortly.
> From: Scott McLoughlin <scott@...>
> Date: Sun, 26 Jun 2005 15:25:26 -0400
> Subject: Re: [Digital BW] 2400 - Paper issues
> Scott
Steve,
Thanks. I renamed the rgb files targeted at Qimage to ".icm" extension and
the profiles show up on PWP's Transformation->Color->Change Color Profile
dialog.
Converting an image to RGB Lab has a slightly bluish cast, but looks good.
But converting to RGB Matte Paper makes for an interesting looking image
with quite goldish tones, and the darkest tones "cut off" to a beige-ish
tone.
Is this normal, or am I likely doing something wrong?
Scott
> and can
> > Scott
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> flames. Hostile, aggressive or argumentative users may be removed from
> the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the
> Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd
> AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
> RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> YAHOO! GROUPS LINKS
>     * Visit your group "DigitalBlackandWhiteThePrint
>       <http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint>" on
>       the web.
>     * To unsubscribe from this group, send an email to:
>       DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
>       <mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
2005-06-27 by Steve Kale
I am not familiar with the rgb versions of these profiles - just the
greyscale printer profiles.  I also do not use PWP but if you are able to
work in greyscale then you apply the greyscale ICC profiles to your prepared
greyscale file just prior to printing (or on the fly at printing).
> Date: Sun, 26 Jun 2005 19:54:59 -0400
> Steve,
> dialog.
> tone.
> Scott
>> and can
2005-06-27 by Scott McLoughlin
Roger that. I can well imagine the RGB profiles (Qimage targeted, I
believe),
might look goofy on screen but print properly. I'll give it a try.
I'll also look more closely at whether or not PWP supports icc profiles for
grayscale images (I think not, unfortunately).
Scott
> prepared
> > Steve,
> extension and
> Profile
> > dialog.
> good.
> > tone.
> > Scott
> >> and can
> printer
> photo
> very cool
> this same page.
> keep them short.
> Files section:
> *Yahoo! Groups Links*
>     * To visit your group on the web, go to:
