2200 Ink Diminishing at End of Print
2005-07-03 by Stephen M Martin
I have encountered a new problem with the 2200 which I wanted to see if anyone else has had. In the last half inch or so of a print, the ink suddenly "thins out" leaving an area printed about half way. It happened just now on Hahnemule Photo Rag. Anyone ever heard of this?
Re: 2200 Ink Diminishing at End of Print
2005-07-03 by bwinkjet
If you are using Image Print, this happens when the bidirectional
support is not turned off under ports in the printer properties.
Otherwise I don't know.
HTH
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen M Martin"
