Workflow - QTR, Workspace Profile, Qimage & Eboni?
2005-07-08 by dean_carnagey
I'm still trying to get my head around the various options available
to print B&W in the digital realm.  I've recently read so much about
the subject here as well as other places on the net that my eyes are
bleeding.  However, I still have a few unanswered questions that I
hope a kind soul or two out there will help me with.
I shoot digital (Raw) rather than scan…I'm a Windows user with a
solid color managed workflow...and I'm using an Epson 2200 (for
now).  I've settled on using QTR with the Epson OEM UC inks, and I
plan on using Qimage in my workflow.  (Alternatively, I'd like to use
the above same workflow, but substitute MIS' Eboni ink in place of
the Epson Matt or Photo black cartridge.)
So with that, my questions are as follows:
1  I use Photoshop to make my RGB images appear black and white...
usually using just the two Hue & Sat layers method.  I then edit
these images in my normal workspace (ProPhoto RGB) until I get the
look I'm after.
So my first question is…would there be anything to gain from
assigning Roy Harrinton's RGB-Lab.icc (or Gray-Lab.icc) profile and
doing my edits in this workspace instead?
2  I understand that before saving the file as a TIFF file, I'll need
to do a profile conversion to one of Roy's supplied Matte or Photo
profiles.  I also understand I need to use RGB-Matte or RGB Photo
because Qimage doen't handle grayscale.  I've also gathered that I
can use either Photoshop or Qimage to handle the conversion.  But
since I'd like to use Qimage's interpolation and smart sharpening
features, I was thinking of letting Qimage handle the conversion...
then do a print to file...and then save as a TIFF.
So I guess here my only question at this point is...would there be
any advantage either way as to which application handles the profile
conversion?
3.  Once I have a TIFF file, I understand I can then load it into QTR
and begin applying the supplied or downloaded curves.  As I
understand it, these curves apply the desired toning touches, taking
into consideration the ink/paper combinations.
My question here is...if I desire my file to look exactly as it was
when I saved it (i.e., no toning whatsoever), do I set the toning
slider to 50% between two Cool and Warm curves...or do I choose no
curve at all?
4.  Softproofing...this one has me thoroughly baffled.  I understand
that I can use Roy's Matt or Photo ICC profiles to do a rough
softproofing in Photoshop...but is there any way to see the effect
the toning slider in QTR is having on the image?  In other words, if
I want my image "somewhat" cool...how can I tell if I've got the
right percentage mix?  Is doing a printed proof the only way?
5,  And finally...if I wanted to substitute MIS' Eboni cartridge for
the Epson black cartridge (either Matt or Photo), how much would that
throw off the supplied curves?  I realize the correct way to do
things would be to build my own curve for this altered ink set, but
until I learn a bit more how to do it and can purchase a densometer,
I was hoping I'd be able to use the ink for a bit richer looking
black.
I realize I've prattled on quite a bit here with my questions, so I
want to thank anyone who's read this far for indulging me.  If anyone
would care to take a shot at this list of questions, I'd be most
appreciative...even if you're able to address only one or two of them
it would help tremendously.
-Dean Carnagey
Re: [Digital BW] Workflow - QTR, Workspace Profile, Qimage & Eboni?
2005-07-08 by Steve Kale
> From: dean_carnagey <jd_tazmo@...>
> Date: Fri, 08 Jul 2005 20:20:43 -0000
> Subject: [Digital BW] Workflow - QTR, Workspace Profile, Qimage & Eboni?
> I shoot digital (Raw) rather than scanŠI'm a Windows user with a
> look I'm after.
> So my first question isŠwould there be anything to gain from
No not really as the file will go out with pixel values adjusted when you do
the conversion in 2 below. (more refined profiling is on its way)
> conversion?
I doubt it.
> curve at all?
The way to think about the curves is each is a greyscale made by a defined
use of ink.  You need at least one curve to tell QTR which inks to use and
how.  The slider blends 2 curves.  Getting a curve mix which matches neutral
requires a little experimentation but is around 65 cool/ 35 warm.
 this just soft proofs the tonal compression that is done by converting to
the print profile (grey or matte)
Only by trial and error.  Print a set of step wedges from 100 cool/0 warm to
0 cool/100 warm for example.  Once you've got a mix you like you can create
a proof using the (preserve color numbers) softproofing technique outlined.
> black.
Probably not tooo much.
> Thanks,
> -Dean Carnagey
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the membership
> without notice.
> printing. Users who persistently make off-topic posts may be removed from the
> membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
> Moderators. See ³Group Topic, Rules and Guidelines² in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE ³OWNER² AND
> ³MODERATORS² OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL,
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  ³OWNER² AND ³MODERATORS² OF
> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR
> TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE
> DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE
> DIGITAL BW, THE PRINT YAHOO GROUP.
2005-07-08 by Dean Carnagey
Thanks, Steve, that helps.  A quick follow up question or two, if you
don't mind...
defined
use and
matches neutral
So, then, if I end up building the proverbial dead-nuts neutral
curve, I can simply use one curve (I guess it would show the same
name in both places in the GUI)...and say, set the blending at 50%?
Or maybe I should rephrase it by asking...is there anytime one would
normally just use one curve?
"but is there any way to see the effect the toning slider in QTR is
having on the image?"
can create
outlined.
Understand about printing the step wedges...but I guess I haven't
come across the "softproofing technique outlined".  I haven't
downloaded QTR as yet, so if this is contained in the read me file or
something, no need to recite it as I can easily look it up myself.
However, if this is technique is outlined someplace else, I'd
appreaciate a pointer to it.
Thanks again,
-Dean Carnagey
2005-07-08 by Brian Ellis
I don't see any significant difference. I've been using MIS Eboni in place
of MK since shortly after QTR came out and the supplied curves for EEM and
PFA seem to work fine with it. FWIW I use 75% cool 25% warm when I want a
neutral print (to the extent there's such a thing as a "neutral" print).
Sent: Friday, July 08, 2005 5:08 PM
Subject: Re: [Digital BW] Workflow - QTR, Workspace Profile, Qimage & Eboni?
> I shoot digital (Raw) rather than scanSI'm a Windows user with a
> look I'm after.
> So my first question isSwould there be anything to gain from
> conversion?
I doubt it.
> curve at all?
> black.
> Thanks,
> -Dean Carnagey
> page.
> them short.
> membership
> without notice.
> the
> membership.
> and
> Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND
> \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU
> GOODWILL,
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND
> SUCH
> BW,
> THE
> THE
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
2005-07-09 by Steve Kale
Dean
You can always use just one curve by selecting 100-0 or 0-100.  And it
doesn't have to be neutral.  For example, if you wanted sepia then you would
just select sepia 100 and x 0.  Re soft proofing the technique is referenced
on Roy's site:
http://harrington.com/QuadToneRIP.html#softproof
See the "download this" part.  You need an Eye One to do it.  Net net though
I think you will likely softproof hue less than the tonal compression part.
I would keep the step wedges for different curve mixes on the same page as a
ref, soft proof the tonal compression with the printer ICC profiles and test
print your curve mix with a full print.  Hope this makes sense (Friday night
and a few vodka gimlets under the belt...   :-)  )
Steve
> From: Dean Carnagey <Mister_Tazmo@...>
> Date: Fri, 08 Jul 2005 22:49:58 -0000
> don't mind...
> defined
> use and
> matches neutral
> can create
> outlined.
> Thanks again,
> -Dean Carnagey
2005-07-09 by Dean Carnagey
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
<stevekale@b...> wrote:
> Dean
it
you would
referenced
> on Roy's site:
net though
compression part.
page as a
and test
(Friday night
> Steve
I think I'm beginning to get the full picture.  A bit more to it than
I originally thought, but I think I understand.  Actually, I'm about
ready to start my own little happy hour by beginning to crank out
some test prints.  Got a feeling this will be a late, but enjoyable,
night.
Enjoy that Gimlet, Steve...and thanks!
