Sensor Dynamics
2005-07-10 by claudej1@aol.com
In a message dated 7/9/2005 2:04:11 P.M. Eastern Daylight Time, DigitalBlackandWhiteThePrint@yahoogroups.com writes: Now maybe someone will concentrate on the sensitivity and dynamic range of the sensor and associated electronics. Truman I don't think dynamic range compression has ever been an issue with film. Nor is it now an issue with digital capture. I agree with your statement about diminishing returns of the filtering technique. While I have been known to shoot over 3,000 jepeg images at a Hindu Wedding, when I am doing 'high end" photographs, like commercial/architectural work or landscapes fro myself, I shoot RAW. For gosh sakes, the sensor in the Canon 1D Mark II has a linear capture range of around 12 1/2 stops with the 20 D sensor within 1/2 stop of that. I can't imagine the Digital Rebel sensor is much worse. Or you have the Fuji S3 with it's single-shot dual layer dynamic range. So what what more can we possibly want!! You can then do a luminance compression using dual file processing for both ends and layer them together. You can then blend the midtones/highlights from the dark one into the Shadows/midtones of the bright one.....or just do more than one exposure on a tripod to be combined/processed/post filtered later. You can then use the High Dynamic Range (HDR) features in Photoshop CS2 to make whatever image you want. Couple that with post processes involving Hue/Saturation methods, gradient mapping, curve manipulations, etc. and you have more ways of controlling B&W than we ever had with colored filters on various pseudo-panchromatic emulsions. It's the same technique that musicians use to "Get to Carnegie Hall".....practice, practice, practice!! Claude [Non-text portions of this message have been removed]
