Creating curves with 21step & curve template
2005-07-14 by Chris Aitken
Hi all,
I have printed off Paul R's 21step from [1], and then using a densitometer
here at work, put the figures into the Curve Template spreadsheet [2].
Here are my results:
	|densities-----------|	Photoshop RGB-----|
Step	measured	corrected	input		output
					measured	nominal
0	0.89		0		255		255
5	0.94		0.05		239		242
10	1.02		0.13		215		230
15	1.11		0.22		190		217
20	1.16		0.27		177		204
25	1.22		0.33		163		191
30	1.27		0.38		151		179
35	1.35		0.46		134		166
40	1.41		0.52		122		153
45	1.47		0.58		111		140
50	1.54		0.65		99		128
55	1.62		0.73		86		115
60	1.68		0.79		77		102
65	1.76		0.87		66		89
70	1.83		0.94		57		77
75	1.92		1.03		46		64
80	2.01		1.12		37		51
85	2.17		1.28		22		38
90	2.36		1.47		7		26
95	2.39		1.5		5		13
100	2.46		1.57		0		0
My value for the paper base is also the same as the zero step - I'm guessing
that this is what it should be (as the results look similar to the
as-downloaded results.
Now where to input these figures into photoshop? The transfer function curve
in the print dialog requires percentages - as does the curve tool. I'd
really appreciate some guidance here!
Cheers
Chris
[1]
http://f2.grp.yahoofs.com/v1/cA3WQssvJtKYYC_rD-ac2sdm-peMBhBOc8AOz3RKssEchbi
KTZ25-bvZcLwsehOkgSA9XWalogbaJZp584XO7hGptJQFBl1NEMimXbN3/Image%20Processing
/21-Step%2B.jpg
[2]
http://f1.grp.yahoofs.com/v1/cA3WQtp3fQiYYC_rmFvDtwxzj6vb7npe3DbP4_h4Y9O_m4K
b6oIistFtzBTB5vlmIG1iA0rYl_DY1BWj38AAl9-JWil1-3F8lMm3eMT6/Image%20Processing
/CurveTemplate.xls
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
