Epson 2400 -- ABW Mode vs. ICM
2005-07-17 by wwodets
I'm wondering about the use of the ABW Mode and what advantages it
provides over a regular ICM flow using the supplied Epson paper
profiles or custom profiles.  The latter, of course, allows a soft
proof mode in PS, which the ABW (to my knowledge) does not.   I realize
that the ABW mode allows toning, but other than that does it offer
something?  I had understood earlier on that ABW provided special
dithering and a minimal use of color inks.  I have printed both ways
(but only on matte papers with MK), however, and I can see no
difference in dithering, ink usage or appearance of the prints.  I have
examined the prints by eye and with a 7-35X zoom microscope and I
believe they are identical, the ICM prints very closely matching the
ABW "Neutral/Normal" (not "Neutral/Darker") prints.  Both work flows
are providing excellent prints, but ICM system provides a better screen
preview.
Any comments or thoughts on this would be *much* appreciated.
Walt
re: Epson 2400 -- ABW Mode vs. ICM
2005-07-18 by Scott Jones
There have been quite a few posts on the new R2400 printer revolving
around whether to use color management or not when using the
Advanced B&W feature of the driver. I just got mine yesterday and
read the manual which really did not address this issue so I thought
I would call Epson and share their tech support answer with you all.
They told me that 90% of users are finding that using NO color
management before sending the file (RGB or Grayscale) to ABW is the
best way to go, but that there is a minority that ARE using color
management before sending the file and like that better. Their
advice is that one should experiment with the two methods to see
which you like better and that there is NO ONE RIGHT ANSWER. He said
results are "in the eyes of the beholder". They advise the no color
management method as a starting point and see if you like the
results.
I also asked them if there will be any difference between "no color
management to AWB" and simply "using color management and skipping
the AWB". Again he said people are having different experiences and
they do not state that there is a right way but recommend using the
ABW method as a starting point.
Interesting! So hopefully we can get lots of discussion going on
what people are seeing with all the above methods for B&W printing
using the R2400.
Cheers
Re: Epson 2400 -- ABW Mode vs. ICM
2005-07-18 by wwodets
Thanks for the reply.
It sounds as if Epson is suggesting color management in PS (using the
supplied output space profiles or others) but using ABW (rather than
ICM/No Management) in the driver.  I'm not clear on the logic of
this, but I'll try it.  Printing only BW, I have used the profiles
with an ICM flow, but in fact I'm getting a better screen match using
my own Soft Proof profile, no PS management and ABW (using the ABW
controls to acccount for different papers).  The prints, however, are
very good either way.  So I'll try what I think you are suggesting.
Walt
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Scott Jones"
revolving
thought
> results.
> using the R2400.
> Cheers
2005-07-18 by Carl Schofield
The ABW and RGB-icc workflows do produce similar looking prints, but there are some
subtle differences.  Looking at paired prints on premium glossy in both halogen or
incandescent and then daylight I can see some slight metamerism in the form of a faint
magenta cast in the midtone grays in the RGB print - also a little magenta/green
crossover.  Measured dmax is also higher for the ABW print (2.47) vs the RGB-icc print
(2.28).  Neutrality is slightly better with the ABW print as well (see data in linked file below)
and just looking at the two side by side suggests a slightly more bluish hue overall in the
RGB print.  All of these difference are subtle and not significant unless you are looking at
side by side prints generated from both methods.
http://homepage.mac.com/scho/abwrgb.jpg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "wwodets" <odets@c...> wrote:
> preview.
> Walt
Re: [Digital BW] re: Epson 2400 -- ABW Mode vs. ICM
2005-07-18 by Douglas meeuwsen
Wow...I saw no difference, but I only tested on one image...DM
>  results.
>  using the R2400.
>  Cheers
>  If you wish to receive no emails or just a daily digest, or you wish
> this same page.
>  Please follow these basic guidelines:
>  - As threads develop, trim off excess portions of earlier messages to
> keep them short.
>  - Good manners are required at all time. No personal attacks or
> flames. Hostile, aggressive or argumentative users may be removed from
> the membership without notice.
>  - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
>  - By posting on this forum you agree to abide by the group rules and
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See “Group Topic, Rules and Guidelines” in the
> Files section:
>  BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER”
> AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
> RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> YAHOO! GROUPS LINKS
> 	▪ 	 Visit your group "DigitalBlackandWhiteThePrint" on the web.
> 	▪ 	 To unsubscribe from this group, send an email to:
>  DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
> 	▪ 	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
Carl-
Many thanks for the response.
I have none of these differences between and ICM flow and the "No
Management" ABW flow and I have gone through the multiple light
sources, viewing angles, etc.  I am however sending grayscale files
from a 2.2 workspace and printing only on EEM (on which I do not get
acceptably even blacks by the way) and on Epson Velvet (on which I
get terrific, smooth, deep lacks).  I am using only MK.
For now I am staying with the ABW, largely because I have a better
screen match--an excellent & consistent one, surprisingly--by using a
profile with 30% dot gain and Preserve Numbers.
Do these differences account for the differences in our
observations?  I am a digital neophyte, but I have been priting B&W
since 1965 and have a pretty good eye for a print.
Good wishes,
Walt
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Carl Schofield"
but there are some
both halogen or
the form of a faint
magenta/green
it
soft
realize
offer
ways
I have
flows
screen
> > preview.
> > Walt
Re: [Digital BW] Re: Epson 2400 -- ABW Mode vs. ICM
2005-07-19 by Carl Schofield
Walt,
On Jul 18, 2005, at 7:38 PM, wwodets wrote:
> Carl-
You might want to also try using Roy Harrington's QTR gray work space
and his matte gray icc profile for print space when printing with the
ABW workflow on matte papers.  If you have an i1 you can also make
your own gray icc profiles for printing and softproofing.
> observations?
Could be as I was using PK ink only with RC paper.
> Good wishes,
> Walt
Carl
