More R2400 ABW experiments + Ink costs
2005-07-22 by Scott Jones
Greetings,
Having a fun evening here with the R2400. After having printed three
varieties of a B&W print with the settings "neutral" with one of the
three settings "normal", "dark", and "darker" and finding that
"darker"
matched my calibrated screen best (6500K), I thought it would be fun
to
play with the color toning wheel.
The color toning point is moved using a combination of horizontal and
vertical click/movements toward the edge of the color wheel. If one
goes straight horizontal or straight vertical, one can get 75
click/increments. If one uses equal horizontal and vertical
movements,
as one would want to do to warm up an image, one can get 53
increments.
This is the route I chose.
I started with 10 clicks up and 10 click to the right and the results
were very obvious "sepia" type toning and the effect was obvious and
dramatic with a very warm tone. 53 clicks would be wildly sepia. I
then
did trials of 5 up 5 right, and 2 up 2 right. The last 2 click move
represents ~4% of the available motion available and still made an
easily noticeable warming of the image. Without a comparison, a
viewer
would still see this image as neutral, but with the comparison to the
unaltered print, there was an obvious subtle warming. I suspect just
one click up and right will also be visible and will just take the
slight cold edge off the print.
Also did a quick look at costs so far. I have printed 3 8x8s, and 4
3.5x3.5s. The image had some very dark areas. Here is what the ink
tanks had left:
LLK 95%
LM 90%
LC 95%
LK 90%
PK 85%
C 95%
M 95%
Y 97%
I had loaded the machine with ink and turned it on and off twice.
Total square inches was 241. Cheapest ink I can find is at Atlex at
11.20 per cart so the cost is .027/sq", so and 8x10 cost $2.16 in ink.
Just one man's experience so far.....
Scott
