Re: [Digital BW] Re: Eye-one: extract more info?
2005-07-23 by Bob Frost
Frank,
I seem to remember reading that BasiColor will allow you to do this; just
checked and the manual says:-
"Clicking on the "Chromaticity Coordinates" radio
button activates the "Measure" button, which allows you to use the
calibration sensor
connected to your computer to measure various sources of light. You can
measure the
true color temperature of your light booth, for example, which often
deviates from the
standard 5000 Kelvin,"
Bob Frost.
Does anyone know of software that will use an Eye-one display (the version 1
that was on sale recently) as a simple photometer? It seems like the only
way to use it is on a monitor running some dedicated software, Match or
maybe BabelColor, but there may be some other software out there that can
let the Eye-one hardware act as a simple color photometer, if the firmware
that senses a screen raster (?) can be bypassed.
2005-07-25 by Bob Frost
Frank,
It works with the i1 spectro, not the i1 display colorimeters. BasiColor
seems to get great reviews from the experts, and it has been able to
calibrate and profile lcds to give perfectly neutral grayscales that other
programs cannot. It has got rid of a color cast on my lcd that Colorvision
and iMatch could not, and Bruce Fraser has reported that he found it did the
same with his monitors.
Bob Frost.
Was that the "Eye-one display" (version 1) or ". . . display 2", as they
named them? Display 2 has that capacity with Match software, but the
original version has some inherent limitation that cripples it for
GretagMacbeth's Match software and, apparently, for BabelColor also.
