GRETAGMACBETH EYE-ONE DESIGN for QTR
2005-07-31 by Mr_Misty_44
Is the entry level GRETAGMACBETH EYE-ONE DESIGN all I need to do my
own profiles in QTR using Epson Ultracrome or K3 inks as well as any
other ink set. Is it overkill or not enough? I've previously use an
old X-Rite 400. Using the colored inks do I need a colorspectrometer.
John H
Re: GRETAGMACBETH EYE-ONE DESIGN for QTR
2005-07-31 by dfaprinting
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mr_Misty_44"
any
colorspectrometer.
> John H
If all you need is the spectrophotometer, then the Design is just
fine. The "small patch technology" really doesn't work for making
full color profiles! I bought the Design because I needed a new
spectro, and tried the software just for fun. The small patch CMYK is
the ugliest result I have ever seen!!! Even after setting up a new
RIP and making sure all the limiting and linearizations were correct,
that small CMYK target could not make anything that even comes close
to correct. The RGB is only slightly better.
The good thing is the Design comes with a 50% off coupon for an
upgrade to the full RGB or the full CMYK, so you can get the same
ability as the i1 photo at making printer profiles for a few hundred
less (RGB profiles). You won't get things like the beamer hardware,
and a couple other things, but you might never use those anyway.
You might consider getting the UV filtered Design, but that's up to
you. I also suggest downloading the Colorport utility from Xrite,
it's free for now. Search here for more info on Colorport.
