Re: [Digital BW] Measuring density
2005-08-10 by Ernst Dinkla
Chris Aitken wrote:
>Is there a real issue with measuring paper via transmission (assuming the
>paper base has a constant transmission)?
I think there are many reasons why that would never become a practical
solution. But that would be a longer message.
Ernst
RE: [Digital BW] Measuring density
2005-08-10 by Chris Aitken
> (assuming
> >the paper base has a constant transmission)?
> practical solution. But that would be a longer message.
Please, post the longer message. I am interested.
Chris
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
Chris Aitken wrote:
>I have access here to a Gretag Macbeth TD932 (transmission densitometer),
The least I would be worried about is the consistency of the paper's
light transmission :-)
The object of the measurements  is for correcting the ink density to get
a perceptual correct representation of the light reflecting off the
print. It would be different for a print that is mounted on a lightbox.
Then your transmissive densitometer could work correctly (depends on the
design though).
There must be a significant difference between both types of
measurement. Especially with pigment inks that are more opaque and at
the other hand reach their Dmax in reflection measurement sooner as the
light reflecting from the pigment layer will not diminish above a
certain amount of ink and the light transmission will still diminish
with more (opaque) ink laid on top. In practice this would mean an ever
increasing density reading in transmissive measuring (till the Dmax of
the densitometer is reached or no more ink possible) while the inklimit
for prints is already passed. With the more transparent dye inks where
the top of the ink layer reflects less light this will be less dramatic
but still give too much difference between the transmissive and
reflective readings. I doubt there's even a nice relation between the
two that will allow you to add a compensation curve for one or more inks
and papers. The paperbase will deflect the light transmitted so even for
transmissive measurements you will need compensations to get figures
comparable to film readings, the desitometer design plays a role there
too. Less than with film there will also be a difference between
measuring with the light source at the emulsion/ink side and with
measuring with the light source at the film/paper side. Dotgain will
also work out differently in reflective and transmissive density.
With signs that are lit by the lightbox at night and by sunlight at day
the practical solution is to use two prints at both sides of the paper
(or on white vinyl, PET etc) the one at the back reversed in print. A
normal print for reflective light is too low in density on a lightbox,
the extra print at the back assures the density increases for the
transmitted lighting.  There are inkjet sign printers that have head
arrangements at both side of PVC fabric for that purpose. I think they
use a plain ICC profile created for reflection only at the front (but at
6000K or higher) and transmissive one for the different fluorescent
light at the back + a lot of editing on the profiles. I've done similar
things on taxi toplights in silkscreen printing (no fc just spot colors)
to compensate for the warm tungsten light inside. For example a chrome
yellow printed on a citron yellow to get a similar yellow in both
conditions, the Dutch railway design dept is that demanding.
Ernst
