Measuring density
2005-08-10 by Chris Aitken
I have access here to a Gretag Macbeth TD932 (transmission densitometer), and also a PerkinElmer Lambda 9 spectrophotometer. I am aware that one is supposed to use a transmission densitometer for film, and a reflection densitometer for paper. However, I have profiled some paper using Martin Wesley's excel spreadsheet [1], and the results from the TD932. The profiled 21step wedge looks much better (Ilford Classic Gloss, dMax = 1.57 (HP920C with OEM black)). Is there a real issue with measuring paper via transmission (assuming the paper base has a constant transmission)? Regarding the spectro (a huge beast), I could measure the reflection by cutting each of the steps out, and placing them on the reflection stage. This would then give me the percentage reflection per step. How does one then create a curve, knowing the nominal %K of the step, and the measured reflection? Thanks, Chris [1] http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/Image%20Pro cessing/ -- This message has been scanned for viruses and dangerous content by MailScanner, and is believed to be clean.
