Up-rez and print at 360 or print at 300?
2005-08-23 by Steve Kale
Given all the Genuine Fractals etc discussion I was wondering what people's thoughts were on this. Is it best to lower the dpi and gain size (say 360 down to 300) or interpolate up (through whatever method) and maintain the dpi? Cheers Steve
2005-08-23 by John Moody
I believe it depends on the difference between ones ability to up-rez and sharpen, vs. what algorithms have been put into the driver, RIP, etc.. Certainly between 300 and 360 we would be talking about pretty subtle differences that require a demanding eye, and side-by-side review. Best regards, John Moody
-----Original Message----- From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Steve Kale Sent: Tuesday, August 23, 2005 9:41 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Up-rez and print at 360 or print at 300? Given all the Genuine Fractals etc discussion I was wondering what people's thoughts were on this. Is it best to lower the dpi and gain size (say 360 down to 300) or interpolate up (through whatever method) and maintain the dpi? Cheers Steve [Non-text portions of this message have been removed]
2005-08-23 by Richard Orban
I don't know what's "best" - here's what I do: I'm printing to an Epson 7600 using ImagePrint so I keep my PS print documents (flattened TIFs) at 360. I do all image restoration and processing at the scan resolution of 400 dpi. I use GF to enlarge in 1.5" steps while keeping the 400 dpi resolution. Then use PSCS to convert to 360 dpi so that ImagePrint/Epson doesn't do it. I'm satisfied with B&W that I get off the 7600. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steve Kale" <stevekale@b...> wrote: > Given all the Genuine Fractals etc discussion I was wondering what people's thoughts were on > this. Is it best to lower the dpi and gain size (say 360 down to 300) or interpolate up
> (through whatever method) and maintain the dpi? > > Cheers > > Steve
I had always sent prints at 360 because, if I recall correctly, supposedly the Epson driver for the desktop machines uses 720dpi and hence I was giving the print driver an easy up-res. I am not sure what the 4800 driver uses. I seem to recall the large format drivers using 360. I guess I will stick with my 360 and up-scale even if 300 would get me there.
2005-08-23 by john dean
Yea, I would rather send the file over there at 300 or even 240 than have to resort to upsampling. Through the years I have been amazed at how efficient the Epson driver is at functioning at less than perfect file sizes. But, of course this is image and scan dependent. You can get away with more from a drum scan than a 20D file or a nikon scan for instance - or from a scan of a bunch of trees than a subtle tonal gradation. John --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Moody" <moodymz3@y...> wrote: > I believe it depends on the difference between ones ability to up-rez and > sharpen, vs. what algorithms have been put into the driver, RIP, etc.. > Certainly between 300 and 360 we would be talking about pretty subtle > differences that require a demanding eye, and side-by-side review. > > Best regards, > John Moody > > -----Original Message----- > From: DigitalBlackandWhiteThePrint@yahoogroups.com > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Steve Kale > Sent: Tuesday, August 23, 2005 9:41 AM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: [Digital BW] Up-rez and print at 360 or print at 300? > > Given all the Genuine Fractals etc discussion I was wondering what people's > thoughts were on > this. Is it best to lower the dpi and gain size (say 360 down to 300) or
> interpolate up > (through whatever method) and maintain the dpi? > > Cheers > > Steve > > > > > > [Non-text portions of this message have been removed]
2005-08-23 by Ernst Dinkla
Steve Kale wrote: >I had always sent prints at 360 because, if I recall correctly, supposedly >the Epson driver for the desktop machines uses 720dpi and hence I was giving >the print driver an easy up-res. I am not sure what the 4800 driver uses. >I seem to recall the large format drivers using 360. I guess I will stick >with my 360 and up-scale even if 300 would get me there. > > > Some fine modes of the 4000-7600-9600 Epson drivers have 720 PPI native resolution as well so I expect the same for the 4800. With Qimage I do not worry what I send to the printer. The file can be kept in its original (scan) format and the up or down sampling to the driver's native resolution is done well with Qimage. If there's an overload of information: 6x6 or 6x9 scanned at 4000 PPI and used for (a series of) a small print(s) then I tend to do a downsample to 360 PPI as otherwise it takes much more time in processing, Qimage's interpolation etc settings on "off" then. That file goes in the dustbin afterwards. Ernst
2005-08-23 by kenstrain2000
Steve, growing curiosity was pushed over the edge into action by your post. I did not have time to do a comprehensive test but was curious to see the magnitude of any effects. My mono printer is a 1270 with some MIS UT FSN inks - not the whole set and used with my own curves (which are OK but not perfect). This is clearly non-standard so I also carried out the same experiment in colour on a 1290 with MIS archival inks, and also in BO with eboni on the 1290). Normally I feed the printers with 200 ~ 360 ppi images. I expected that the 200 dpi end would be the best test. Question: is there a significant difference in the appearance of a 200 ppi image sent to the 1270/1290 EPSON drivers compared to the same image printed after first interpolating by a known algorithm. The most convenient pre-print interpolation I had available was to use Picture Window Pro. In a pre-test I looked at both bicubic with 16.7% sharpening and Lanczos 6x6 and, given how close the results were in that test decided to use the former method for the other tests. (I do not posses PS.) Interpolation was done to 720 ppi. Prints were all to the same size (about 10"x15"). The test image was of some tree canopies in generally high contrast lighting, with sharp, unsharp, high-contrast and low-contrast areas. There was some image noise in the lower zones, from the camera, I suspected that such noise might be a good way to distinguish the methods. A wider range of test images would, naturally, be needed to form a firm conclusion. Answer: the interim conclusion is that differences due to the method of resampling were very minor. There were just-perceptible differences in the background "noise" in some dark-mid-tone out-of-focus areas, but nothing else I could distinguish from 10 inch viewing distance in good light. I suspect that very small changes to sharpening explain the difference (on second thoughts this is pretty obvious: the processes involved are linear and include interpolation and sharpening, with what comes down to, probably, tiny differnces in the "effective" kernel for the whole process if it were to be reduced to a single step). Perhaps the "smart" approach in Qimage is different - I downloaded it to try but had some problems and do not now have time to test it properly. What now? At the moment this aspect is not going to be my highest priority in terms of workflow improvement, so no more tests in the immediate future, and I'll trust the drivers to do the (modest) resampling. If someone is surprised by this, I'd love to hear the details of the contrary evidence, as I could quite easily have missed an important point in what was a cursory test. I find it quite probable that the methods in the printer drivers break down when the resampling ratio gets too large, but that is not happening in the regime in which I work. This post has grown too long. Ken --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steve Kale" <stevekale@b...> wrote: > Given all the Genuine Fractals etc discussion I was wondering what people's thoughts were on > this. Is it best to lower the dpi and gain size (say 360 down to 300) or interpolate up
2005-08-25 by brucenorikane
"kenstrain2000" <kenstrain2000@y...> wrote: ... > Question: is there a significant difference in the appearance of a 200 > ppi image sent to the 1270/1290 EPSON drivers compared to the same > image printed after first interpolating by a known algorithm. ... > Answer: the interim conclusion is that differences due to the method > of resampling were very minor. I had the same result a several years ago and stopped adjusting images to a magic dpi before printing. Bicubic was the best interpolator that I had at the time. The Epson diffusion dithering seems to hide most interpolation artifacts in normal photo images. The entire issue went away when I switched to Qimage printing. You might see more of a difference with one of the fancy interpolation + print sharpening applications like QI.
2005-09-07 by Bob Frost
John & Steve,
A belated reply, but after years of discussing this on the old Epson-Inkjet
list, Kennedy McEwan (who designs digital electronic kit) summed it up by
advising that:-
if the ppi is between 240 and 480 at your print size, leave it as it is.
If it is below 240ppi, upsample to 360ppi, and if it is above
480ppi, downsample to 360ppi.
All Epson desktops upsample in the driver (by various methods?) to 720ppi,
old wideformats to 360ppi, and newer wideformats to 360 or 720ppi.
Although ppi that are not integers of 720 give rise to aliasing patterns
with images of repeating patterns, with normal images this is unlikely to be
seen. Upsampling to 720ppi as QImage does can also apparently have some
undesirable side-effects, but they are also not normally seen. Upsampling to
720ppi in QImage gives you the option of using better upsampling algorithms
than those that are used in the Epson driver, but of course 720ppi images
get rather large!
There is no magic at all in the widely-used 300ppi; it will lead to aliasing
with patterns, and apparently arose simply because it is 2x a 150lpi
line-screen.
Tests have shown that people can see improvements in resolution up to about
600ppi (if you have that genuine resolution), and some recent printers can
resolve lines at about the same resolution.
Bob Frost.----- Original Message ----- From: "john dean" <deanwork2003@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Tuesday, August 23, 2005 3:49 PM Subject: Re: [Digital BW] Up-rez and print at 360 or print at 300? Yea, I would rather send the file over there at 300 or even 240 than have to resort to upsampling. Through the years I have been amazed at how efficient the Epson driver is at functioning at less than perfect file sizes. But, of course this is image and scan dependent. You can get away with more from a drum scan than a 20D file or a nikon scan for instance - or from a scan of a bunch of trees than a subtle tonal gradation. John --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Moody" <moodymz3@y...> wrote: > I believe it depends on the difference between ones ability to up-rez and > sharpen, vs. what algorithms have been put into the driver, RIP, etc.. > Certainly between 300 and 360 we would be talking about pretty subtle > differences that require a demanding eye, and side-by-side review. > > Best regards, > John Moody > > -----Original Message----- > From: DigitalBlackandWhiteThePrint@yahoogroups.com > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Steve Kale > Sent: Tuesday, August 23, 2005 9:41 AM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: [Digital BW] Up-rez and print at 360 or print at 300? > > Given all the Genuine Fractals etc discussion I was wondering what people's > thoughts were on > this. Is it best to lower the dpi and gain size (say 360 down to 300) or > interpolate up > (through whatever method) and maintain the dpi? > > Cheers > > Steve > > > > > > [Non-text portions of this message have been removed] Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Links
