R2400: Some Paper Profiles Do not show
2005-08-27 by mxgo95747
The following paper profiles are "Greyed Out" in the printer ABW dialoque box with either Mk
or Pk inks:  "Vevet Fine Art Paper", "Water Color Paper - Rad. White", and "Ultra Smooth fine
Art," therefore, are not accessible.  However, they do show in Print Preview (PS CS) profile
box.
I have a MAC G4, PS CS, firewire connection.
Any ideas?
Martin
Re: R2400: Some Paper Profiles Do not show
2005-08-27 by wwodets
Check the maintenance tab to make sure that the MK is shown as
installed.  And also check the paper feed (source, e.g., "sheet") in
the Epson driver.  For example, VFA will not show up if "sheet" is
selected, etc.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mxgo95747"
> box.
> Any ideas?
> Martin
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "wwodets" <odets@c...> wrote:
> installed.
  Done that.
> selected, etc.
That was it!  I will check Clayton's VFA settings and see the results of printing with that
profile.
Thanks
Martin
RE: [Digital BW] Re: R2400: Some Paper Profiles Do not show
2005-08-27 by Paul Roark
> >... VFA will not show up if "sheet" is selected, etc.
That is strange.  A warning comes up about roll paper.  I hit "ignore" and
the VFA media setting stays there.  I hope I'm getting the correct profile.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...>
I am on a MAC, where is "ignore," when it states "Load this paper....."  Then, can you still load
the EEM paper on the front slot?
Martin
I start with "sheet" paper as the source.  When I hit "Velvet Fine Art" (or
UltraSmooth or Watercolor) a box pops up that is labeled, "Manual - Roll
Required."  It has 2 buttons on it: "OK" and "Ignore."  I just hit "Ignore,"
the box disappears, and I continue to use the top feed tray and print as
usual.  The box is just a warning regarding potential feed problems with
thicker papers.
I'm just testing EEM to see what works best, so I don't know how bad the
thicker papers feed.  I assume for now that it's the same as the older
printers.
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of
> mxgo95747
> Sent: Saturday, August 27, 2005 1:42 PM
> Subject: [Digital BW] Re: R2400: Some Paper Profiles Do not show
> <paul.roark@v...>
> and
> profile.
> Thanks,
> Martin
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
> and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
> thicker papers.
The MAC print box does not have that option.  You have to select "manual - roll" before the
VFA setting shows and there does not seem to have an "ignore" option.
Any MAC users with the same problem?
Martin
2005-08-27 by Clayton Jones
Paul,
>bad the thicker papers feed.  I assume for now that it's the same
>as the older printers.
The 2400 is a much more finicky beast than the 2200 was.  It takes
more finesse to get it to accept a thicker paper.  I find that just
the barest weight of a finger is best, just enough to get it into the
slot where it can be grabbed (also helps if a thicker paper is bent a
little bit concave).  Push a bit to much and it just spits it out the
front.  Sort of like this printer is from Paris, where the 2200 was
from Buffalo.
Clayton
2005-08-28 by wwodets
This is like my driver on the PC--I have no "ignore," and I have to
feed the VFA through the top, rearmost slot.  The printer will report
no media if I try to use another slot with VFA selected as the paper.
<paul.roark@v...>
Fine Art" (or
hit "Ignore,"
print as
problems with
> > thicker papers.
option.
> Martin
