Re: [Digital BW] Re: Using Type 55 Polaroid
2005-08-31 by Paul Aparycki
>One question I have is: do you need to worry about keeping the film >separated while they are in the sulfite solution or is it ok to >stack them together in the solution? >Thanks, >Randy If you are referring to being in the studio and just dropping them in a tray . . . maybe. However, the surfaces are fragile when wet, to my mind, more so than regular film . . . I also "squeegee" very carefully between two smooth, photo-flo-ed fingers . . . NOT a good practice, but I have years at it so it is now no longer a "practice", it is an expertise??. The bucket is still available, and for what it costs I think it gives great peace of mind. Outside of a studio I wouldn.t think of doing without it . . . a bit of an unfair statement as I don't process the stuff until I get back to home base. If you are looking for the bucket, it is available at B&H of course (their part #POPNCT). It costs less than $50 and it comes with a pound of sodium sulfite, which by the way, you don't really need. You can wash with water (longer and wasteful of a diminishing resource), and carefully stroke away the goo, then as with the sulfite, you can fix and wash after. Paul Aparycki
