Vertical Banding on 1290s using QTR and UT2 inkset
2005-09-06 by Jamie Creed
I'm trying to create some curves (in QTR) for Epson Glossy and
Semigloss for my 1290s, but can't get rid of a vertical banding
pattern (that is to say - in the same direction as the printer head
motion) which is showing up on the initial 100% Ink Pattern Page (in
calibration mode.) I've not seen this when printing to Matte paper,
and have tried numerous head alignment operations. Also tried
different settings in QTR; speed, resolution and dithers.
Anybody out there got any ideas or solutions?
regards, Jamie Creed
Re: Vertical Banding on 1290s using QTR and UT2 inkset
2005-09-10 by Jamie Creed
OK I know I'm replying to my own post, but I thought someone might
benefit from my struggles, and maybe someone maybe able to explain
why the solution I found works.
I was having awful banding problems, when playing around with Epson
Glossy and Semigloss; didn't get any reply's on this or DBWTP forum,
so I kept searching the archives, until I came across some threads
with major contributions by Clayton Jones (wow, what a guy.) Clayton
suggested when trying to do a head alignment operation, that people
should try not to align the heads but rather UN-align the heads.
Well I've got to tell you, as a last resort I tried this and it
worked for me big time, Thanks Clayton very much, and QTR I love you.
Can anybody hypothesize as to why this should be,
regards, Jamie Creed.
P.S. I should have set my head to #8 #8 #8, instead I set #2 #2 #2.
head
(in
paper,
2005-09-11 by Bob Michaels
My guess is that unaligning the nozzles is similar to introducing
vibration into a conventional enlarger column or slightly defocusing
the lens to keep grain from showing in the print.
But if it works, do it.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jamie Creed"
forum,
Clayton
you.
> head
> (in
> paper,
2005-09-11 by Jamie Creed
Cheers Bob, sounds very feasible and obvious when you put it like
that. I've got to tell you though, I don't think my images have
suffered at all to the naked eye. Thanks for your thought,
Jamie Creed
> defocusing the lens to keep grain from showing in the print.
> Bob Michaels
> > might benefit from my struggles, and maybe someone maybe able to
> > explain why the solution I found works. I was having awful
> > banding problems, when playing around with Epson Glossy and
> > Semigloss; didn't get any reply's on this or DBWTP forum, so I
> > Clayton suggested when trying to do a head alignment operation,
> > that people should try not to align the heads but rather
> > UN-align the heads. Well I've got to tell you, as a last
> > resort I tried this and it worked for me big time, Thanks
> > #2.
> > > head motion) which is showing up on the initial 100% Ink
> > > Pattern Page (in calibration mode.) I've not seen this when
