1280: residue advice on new unit
2005-10-03 by Craig Snyder
Hi all, Purchased that 1280 last week and today I've finally had a chance to unbox it and do an inspection. I have found ink residue (this is a refurbished unit) and I'm not too happy about it. I thought I will put all stops on any further activity until I consult with members here. Thanks to all I have helped with info last week to identify the parking pads. I have posted an image of the parking pad, as well as an image of the "ink tank holder" of this machine. 1280 "Ink Tank Holder" http://thecraigsnyder.com/epson1280/IMG_1928_tank.gif 1280 Parking Pad http://thecraigsnyder.com/epson1280/IMG_1934_pad.gif Here is what I have found: - Ink residue inside the "Tank Holder". All points/colors. - Ink residue on the plate next to the parking pad (black plastic on left side), greenish residue but probably a mix of all colors including black. - Apparently no ink residue on the parking pad per se. A Q-tip, as dabbed gently in other areas on the printer, yielded ink but a Q-tip lightly touched on the parking pad yielded no ink. I lightly touched the pad with my finger and pushed down lightly. I found a clear oily liquid on my finger. The pad, though apparently clean, seems to be a bit multi-colored (subtle) in hue (former ink stains?). My questions: - Should I attempt to use this printer for Eboni/UT2, having dye ink residue as it does, or should I buy a new one and put this new refurbished unit on ebay? - Largest concern is cleaing all the right spots in the printer (and is there any ink in the nozzles/tubes too...?). Also a concern about the underside of the "Tank Holder". Cleaning the inks out of the tank holder is do-able, but if there is ink on the top side there may as well be ink on the under side of this black box too. Possibly could mix with MIS ink or get on parking pad? Not an easy area to access for cleaning. Maybe I'm being over-cautious--or maybe I'm not in this case. Though I am a person capable of being highly technical and detailed, I want to spend my time printing and not troubleshooting. Or cleaning, cleaning, cleaning, praying, and cleaning. All advice, experience and best bets on this one are welcome. Thanks in advance, Craig
