Creating a profile for Advanced B&W printing on Epson R2400
2005-10-19 by photofan21
On Monday 10/17/05 Steve Kale wrote, "I have profiled my Epson Adv B&W settings, one for each hue - neutral, warm, sepia and cool." I was wondering how he created the profiles. Can I use the Eye-One Photo system to create these profiles? If so, how do I create them with Eye-One? Do I print and scan a color grid or a gray scale step wedge? How do I use the profiles in PS once I create them? I would appreciate any help Steve or others can provide on this issue. Thanks, Mike Fauman
2005-10-19 by Steve Kale
Mike I and others create these profiles using a module that is part of Quadtone RIP (QTR). The module is called QTR Create ICC. Yes you can use your EyeOne. Download PM 5 from the GM site. In that there is a module called MeasureTool which can be used without buying PM 5 (ie it is fully functional in demo mode). These are Mac instructions but Windoze is broadly, if not exxactly, the same. In the QTR download - shareware $50 - there is a folder called CurveDesign. Drag this to your applications folder. Within this there is a folder called EyeOne and in that there are 4 MeasureTool text reference files. These tell MeasureTool what data you are going to scan. Copy them to Applications/ProfileMaker Pro 5.03/Reference Files/Printer/EyeOne. Back in the CurveDesign/EyeOne folder again are 4 greyscale step wedge tif files that match each of the 4 reference files. Select the one you wish to use for profiling and print it with the particular print settings you wish to profile, eg Adv B&W/EEM paper/Neutral/Darker. It should be printed without colour management. Then use MeasureTool to measure the printed target. MeasureTool saves a .txt file. Simply drag this MeasureTool .txt output file to the QTR-Create-ICC droplet application that sits in the EyeOne folder in CurveDesign. When the app icon highlights release the .txt file and QTR Create ICC will create two files wherever the .txt input is stored. One is an ICC file, the other is a graphical depiction of the data you scanned. You can then use this ICC profile for soft proofing and for printing. For printing, instead of no color adjustment in the PS print with preview pane select Let Photoshop Determine Colors, select the profile you made and Perceptual intent. You will then have luminance managed output. For soft proofing, you will be able to see not only the compressed tonal range of the print space but also its hue. Of course, the profile is only relevant for the workflow settings you profiled. Hope this helps Steve CAVEAT: As noted in the other thread there is a very minor glitch in the hue soft proofing. Keep the MeasureTool output files you generate (ie the files used for input to QTR Create ICC) so that when Roy fixes the minor glitch you cn simply rerun QTR Create ICC and get new profiles.
> From: photofan21 <mike43@...> > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Date: Wed, 19 Oct 2005 01:49:38 -0000 > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Subject: [Digital BW] Creating a profile for Advanced B&W printing on Epson > R2400 > > On Monday 10/17/05 Steve Kale wrote, "I have profiled my Epson Adv B&W > settings, one for each hue - neutral, warm, sepia and cool." I was > wondering how he created the profiles. Can I use the Eye-One Photo > system to create these profiles? If so, how do I create them with > Eye-One? Do I print and scan a color grid or a gray scale step wedge? > How do I use the profiles in PS once I create them? > > I would appreciate any help Steve or others can provide on this issue. > Thanks, > Mike Fauman
2005-10-20 by Steve Kale
Mike Sorry I think I said that Spectral should be checked. It should NOT be. Steve
