i1 Target Scanning technique . . .
2005-10-20 by wwodets
I wondering about the actual techniques people are using to scan targets, for example the QTR Random Gray 51. The issues I can think of are ambient light, patch versus strip, speed on strip scanning, random versus "linear" targets. Perhaps there are others. Thanks, Walt
2005-10-20 by Steve Kale
Random is best. Strip is fine. Patch is painful. The software will tell you if you're going too fast. Ambient light is not a problem. The ICC spec calls for black backing not white.
> From: wwodets <odets@...> > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Date: Thu, 20 Oct 2005 15:44:56 -0000 > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Subject: [Digital BW] i1 Target Scanning technique . . . > > I wondering about the actual techniques people are using to scan > targets, for example the QTR Random Gray 51. The issues I can think of > are ambient light, patch versus strip, speed on strip scanning, random > versus "linear" targets. Perhaps there are others. > > Thanks, > Walt >
2005-10-20 by John Moody
When working on a curve description, I strip scan the 21-gray target. For the final readings, I use patch method, which seems to be more repeatable, to create the icc profile. For 21 patches, that seems fastest, for > 21 patches multiple reads and average using measuretool would be faster. Best regards, John Moody
-----Original Message----- From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of wwodets Sent: Thursday, October 20, 2005 11:45 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] i1 Target Scanning technique . . . I wondering about the actual techniques people are using to scan targets, for example the QTR Random Gray 51. The issues I can think of are ambient light, patch versus strip, speed on strip scanning, random versus "linear" targets. Perhaps there are others. Thanks, Walt [Non-text portions of this message have been removed]
2005-10-20 by Ernst Dinkla
Steve Kale wrote:
> The ICC spec
Which is a sensible thing when you have text or images printed
at the other side of the paper too but not for photography
etc. Better use two or three extra sheets of the same paper
you printed on underneath the target. That's what the majority
of the color gurus do.
Other recommendations:
Reading the target three times or even better print three
targets and measure them + averaging the results is something
I now do. I print three on wide paper and have one of the
targets turned 180 degrees in the print.
Drying 12 to 24 hours before measuring. I use an old hair
dryer (cap model) mounted on a box to speed the drying process.
Change an old HP plotter so it can drive your Spectrometer if
you get bored of measuring or if your hand isn't moving
consistently. Drinking a glass of wine is another method.
Ernst Dinkla
www.pigment-print.com
( unvollendet )2005-10-20 by Steve Kale
> From: Ernst Dinkla <E.Dinkla@...> > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Date: Thu, 20 Oct 2005 18:20:18 +0200 > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Subject: Re: [Digital BW] i1 Target Scanning technique . . . > > Steve Kale wrote: >> The ICC spec >> calls for black backing not white. > > Which is a sensible thing when you have text or images printed > at the other side of the paper too but not for photography > etc. Better use two or three extra sheets of the same paper > you printed on underneath the target. That's what the majority > of the color gurus do. There's a lot of debate about this. The spec calls for black backing regardless but this is one of those things that will probably change...
Steve, Ernst, John- Thanks for all the responses. I have been using the random target, 51 patches, strip read, the occasional glass of wine (but not two) and a white card overlaid with a piece of the same paper. I have not been averaging multiple targets or reads, though I've done consecutive profiles and overlaid then and find them extremely close. I imagine that this would have to be done by manually calculating the averages for each of the 51 steps and then entering them in the Measure Tool text file. Is that correct, or is there something sleeker I'm not thinking of? A sample of three is probably better than a sample of one, but *statistically* a sample of three (compared to thousands of prints done with the profile) is probably meaningless (small "N"). Thanks, Walt --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale <stevekale@b...> wrote: > > > > > > From: Ernst Dinkla <E.Dinkla@c...> > > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > > Date: Thu, 20 Oct 2005 18:20:18 +0200 > > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > > Subject: Re: [Digital BW] i1 Target Scanning technique . . . > > > > Steve Kale wrote: > >> The ICC spec > >> calls for black backing not white. > > > > Which is a sensible thing when you have text or images printed > > at the other side of the paper too but not for photography > > etc. Better use two or three extra sheets of the same paper > > you printed on underneath the target. That's what the majority > > of the color gurus do. > > There's a lot of debate about this. The spec calls for black backing > regardless but this is one of those things that will probably change... >
I have not averaged. I don't think the Average module in MT works without the dongle.
> From: wwodets <odets@...> > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Date: Thu, 20 Oct 2005 17:19:21 -0000 > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Subject: Re: [Digital BW] i1 Target Scanning technique . . . > > Steve, Ernst, John- > > Thanks for all the responses. I have been using the random target, > 51 patches, strip read, the occasional glass of wine (but not two) > and a white card overlaid with a piece of the same paper. > > I have not been averaging multiple targets or reads, though I've done > consecutive profiles and overlaid then and find them extremely > close. I imagine that this would have to be done by manually > calculating the averages for each of the 51 steps and then entering > them in the Measure Tool text file. Is that correct, or is there > something sleeker I'm not thinking of? > > A sample of three is probably better than a sample of one, but > *statistically* a sample of three (compared to thousands of prints > done with the profile) is probably meaningless (small "N"). > > Thanks, > Walt >
My youngest son wrote a small command line averaging program
for the PC but for color targets. It might be usable for the
51 steps target but I have to check that. Printing two or
three different targets on a wide format roll at the same time
with one of them 180 degrees turned is a sensible thing to do
as the printer is used that way and by that the drying time
between strokes etc corresponds more to daily practice. I
sometimes observe a small difference in color at the start of
a printjob, having the patches reversed on one target reduces
the problem + printing another file just before it helps too.
Cleaning the heads to get all the nozzles is good too but you
should at least run a normal print before printing the target
to get the head in its normal printing condition.
BTW, Epson has a hidden advice in the Colorbase FAQ that says
no speed printing (bidirectional) is color consistent due to
the reversed order of laying down of the hues and the
increased dotgain. So even for their x800 printers they give
that advice. I have never before seen that advice but always
suspected that something happens in the reversed laying down
order.. Can't recall right now what the subject line was in
the FAQ that covers it but ithe same subject line appears
twice in the FAQ with different underlying texts.
When offset presses are profiled the profile people select a
quantity of say 12 target prints of a print run. Based on
their knowledge at what time the variations in the printrun
occur. The quantity of sheets produced on an offset press with
the same profile must be a 100x more though than what is done
with one profile on an inkjet printer. I'm trying to reduce
reading errors and print variation at the same time. I have to
say that the profiles I made since adopting that method are
more consistent than the ones before.
Ernst Dinkla
( unvollendet )
