On Oct 30, 2005, at 1:11 PM, pekozip93 wrote:
> Hello
> Im wondering how many prints Carl produces in a given week as compared
> to Jenny's volume
> Im considering a 4000 as well for a similiar setup and think that
> maybe the CS positions need to be flowing at least every two days.
> I can recall many posts in the past (not on the 4000 mind you)
> regarding the frequency of operation and clogging with piezotones.
> Im wondering as well if the 4000 head may have more trouble with
> piezotones given its very small droplet size, and thus may require a
> small purge file be run through it daily to keep things flowing.
> Frank
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "byushooter"
> <jellerbe@j...> wrote:
>> Hi Carl,
>> Yes, it's the carbon sepia causing the clogs. No problem with the
>> K7's at all. It would sure be nice if Jon could put the piezotone
>> inks into the same "slippery" base as the K7 inks. I'm not going to
>> give up the carbon sepia tone unless I absolutely have to.
>> Jenny
>> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield
>> <scho@m...> wrote:
>>> Hi Jenny,
>>> I'm running the same setup as you, but haven't had any clogging
>>> problems (yet). Is it the carbon sepia inks causing the clogs?
>> Jon
>>> Cone has commented in a few threads about how the k7 inks are
>>> virtually bullet proof with respect to clogging compared to the
>> other
>>> piezo inks, making me wonder if the carbon sepia are less
>> compatible
>>> and more likely to create problems. As much as I like the carbon
>>> sepia inks, if they start causing clogs I'll get rid of them.
>>> Carl
