QuadToneRIP Curves List?
2005-10-28 by Mike Dobbs
I'm new to this forum and just starting out with QuadToneRIP. I have
an Epson 875 printer running MIS UT-2 ink and have had good results
using Paul Roark's curves in PS6 for printing on glossy & matte papers
using just the Eboni Black ink. Was wondering if any one has created a
QuadtoneRIP curve for printing glossy paper (I like Ilford smooth)
using this same Eboni Black ink? Is there a list of curves I can
search somewhere?
Thanks for the great forum!
Mike Dobbs.
Re: QuadToneRIP Curves List?
2005-10-29 by Steven Karafyllakis
Hi Mike;
You won't find any such curves because the Eboni does not work on RC
papers. The Dmax is low, the ink rubs off, and the bronzing is
extreme. Try the MIS PKN (Phohot Black Neutral) It will do what you
want, though for that printer you may have to make your own curve.
Which is not as daunting as it sounds: read the instructions, skip
the densitometer linearization ( unless you have a densitometer) and
use the Photoshop adjustment curve method to fine tune your curve
instead.
Steve Karafyllakis
have
results
papers
created a
> search somewhere?
> Mike Dobbs.
