Re: [Digital BW] Problem installing R2400 drivers
2005-11-04 by Patrick Carr
You may have tried this, but if not, it might help.
Get rid of the files that were installed (if any)
Access the install CD through file manager (Windows Explorer)
Do a search of the entire disk for the needed file.
Copy the file to your desktop.
Run the install and when asked, direct it to your desktop.
Without sitting down in front of your computer, can't really come up with
anything else--I hope this helps.
Best;
-PC
Carr Imaging
patcarr@...
www.patrickcarrimaging.com
Sent: Friday, November 04, 2005 11:54 AM
Subject: [Digital BW] Problem installing R2400 drivers
> Friends, I have run into a dead end while trying to install the
> drivers for my R2400 with the provided install disc. It gets through
> the first few windows until the image that instructs you to hook to
> printer to the computer. When I do this, I get a message: "Files
> Needed The file epppdtmn.sys on Epson 1394.3 printer Install Disk One
> is needed." When I browse for that file, it is not in the folder. I
> eventually get a message from Windows indicating that there is a
> problem with the installation and that the device may not work. At the
> end of the process I installed the Epson Guide, but none of the
> drivers. I have tried the install several times with the same outcome.
> I then downloaded the drivers from Epson with the same result. I have
> been using the firewire connection but will try the USB when I get
> home. Is it possible that the problem is with Windows? Suggestions?
> Thanks.
