Swapping inks on the newer printers
2005-11-12 by Steven Karafyllakis
Has anyone come up with a way to change sarts in the R1800 or R2400
without triggering an ink charge cycle?
Steve Karafyllakis
Re: Swapping inks on the newer printers
2005-11-14 by koloshor
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
They don't do a "charge" which is about 1/3 of a cart. They just run
enough to clear the fill tubes and heads. You really do want to do that.
2005-11-14 by Steven Karafyllakis
Just the same, if I'm swapping tow carts out of the set to go to a K3
setup, I'd rather not waste even that amount of ink in the remaining
six carts. I'rather come up with a two (or three or whatever) QTR flush
for the exchanged carts-if its possible that is.
Steve Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "koloshor"
that.
Re: Swapping inks on the newer printers-revisited
2005-11-17 by Steven Karafyllakis
that.
OK, once more: call it what you want, I just replaced my NEW M and R
carts with an LK and LLK, and the thirsty little bloodsucker sucked
down 1/3 of the cart on the other six carts. So if anyone does come up
with a viable way to fool these machines, by all means share!
Steve Karafyllakis
2005-11-17 by richard_h95050
Hi Steve,
I think it may have been Clayton who contributed this method:
- When you're ready to change the carts that are low, bring the
carriage to the appropriate position
- Replace the necessary carts but don't press the "ink" button
- Wait several minutes for gravity to "prime" the head with ink from
the new carts
- Turn the printer off and wait a minute or two
- Now when you turn the printer on again, the unit should assume
the "ready state" without triggering a "charging cycle"
I couldn't find the original post, so I hope that I have credited and
quoted it correctly. The method does seem to work just fine...
Hope this helps!
Richard
R2400
run
do
> that.
R
up
> Steve Karafyllakis
Thanks, Richard, I'll try that one again, though I do believe I
tried it a few months backs when I first started using an R1800. I
don't think Clayton's been able to get it to work for his 2400
either-his first post was for the 2200. Anybody have any luck with
this method?
Steve Karafyllakis
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "richard_h95050"
<richardh@j...> wrote:
> Hi Steve,
from
> the new carts
and
> Hope this helps!
> Richard
or
> R2400
just
> run
to
> do
> > that.
and
> R
sucked
come
> up
> > Steve Karafyllakis
