R2400 : Mysterious default behavior of ABW driver
2005-11-13 by petexp2
Does anyone understand what triggers the ABW driver to return
from "light" to it's default "darker" setting AFTER sending a print to
the printer.
The circumstances which seem to trigger this irritating behaviour seem
to involve using a saved custom setting and perhaps modifying it. I am
not entirely sure what is happening but would like to warn others in
case they come up against a similar mysterious glich in the driver
software.
The way around it is to fill in all the relevant boxes one by one
rather than call up this custom setting.
Pete.
Re: [Digital BW] R2400 : Mysterious default behavior of ABW driver
2005-11-13 by Steve Kale
Name and save your settings and then simply load them for each print - a 2
click exercise.  It's not a glitch.
> From: petexp2 <kafoozalem@...>
> Date: Sun, 13 Nov 2005 15:53:38 -0000
> Subject: [Digital BW] R2400 : Mysterious default behavior of ABW driver
> the printer.
> software.
> Pete.
2005-11-13 by wwodets
Pete-
I had completely forgotten this, but the original driver supplied
with the 2400 was fine in this regard.  When I updated the driver
from the Epson website, exactly the problem you describe started and
I returned to the original driver from the CD.  I don't think Steve's
suggestion will correct the glitch.  I posted this problem on the
forum back in April or May.  Unfortunately I no longer have the
driver on CD or installed on the computer and can't give you the
driver numbers.
Walt
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
print - a 2
> > From: petexp2 <kafoozalem@b...>
driver
print to
> > the printer.
seem
I am
in
> > software.
> > Pete.
RE: [Digital BW] R2400 : Mysterious default behavior of ABW driver
2005-11-13 by John Moody
What OS, is the printer directly connected to the one you are printing from,
what connection port on the printer?
I have exactly that happen occasionally on the 2200, and I don’t understand
it.  Printing over the network from WinXP, to a firewire connected 2200 on a
win2k box.
It only happens when messing with saved settings, as you said.
Best regards,
John Moody
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of petexp2
Sent: Sunday, November 13, 2005 10:54 AM
the printer.
software.
Pete.
Re: R2400 : Mysterious default behavior of ABW driver
Seems like I am not going mad after all (though I find it hard to
consistently recreate the problem).
I am using Windows XP Home. The printer is one of two directly
connected to PC. It uses USB 003 port.
I am using the software supplied on CD in UK. I can't find a version
number for it.
Pete.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Moody"
printing from,
> I have exactly that happen occasionally on the 2200, and I don't
understand
2200 on a
> win2k box.
> Best regards,
> John Moody
petexp2
driver
to
> the printer.
seem
am
> software.
> Pete.
2005-11-13 by Clayton Jones
Hello Pete,
>version number for it.
I'm using the driver that came with the printer, and don't have the
problem.  It's version 5.51 (at the bottom of the "Maintenance" tab page).
Clayton
Hi Clayton, Yep mine is version 5.51. Curious...
Pete
<cj@c...> wrote:
> Hello Pete,
page).
> Regards,
> Clayton
