Re: [Digital BW] Epson 2400, Custom ICC profiles and Grayscale printing
2005-11-20 by Tony Riley
On 20/11/2005 01:31:00, garethjolly wrote:
> The problem I'm now having is using the ICC with grayscale printing.
> I can use Photoshop to determine the colours (via Print Preview),
> select the ICC and switch off Colour Management in the print driver.
> But it won't
> let me use grayscale.  I then get a slight colour cast
> when I print.
When printing with an ICC profile you need to make sure your 'grey' file is
an RGB file and you print through the profiled path exactly as you would for
a colour image.
It is not unusual, even with a good paper profile, to find a residual color
cast when printing a colour neutral file. In general, colour printers have
not been a good way to attack monochrome except by using grey inks, RIPS
etc. The new Epson R2400 is however very good with its standard inkset.
TonyR
www.imageplace.co.uk
