Quadtine Rip Problem with Epson 2000P, Help Required
2005-11-22 by jcrcameras
I want to use the Quadtone rip with my Epson 2000P printer but there
are no profiles in the programme for this printer. I can get a print
but it is much too dark. Can someone please help with a source of
profiles for this printer and how to instal them. I really want to
make this work.
Best Wishes,
John
RE: [Digital BW] Quadtine Rip Problem with Epson 2000P, Help Required
2005-11-22 by Paul Roark
John,
> are no profiles in the programme for this printer. ...
See my Readme file at http://home1.gte.net/res09aij/2000P-FS-Readme.htm
The 2000P makes a great matte paper printer with the monotone UT-FS and
UT-FSN inksets.  What you could do if you have a spectrophotometer is use an
ICC in Print with Preview to control the inkset (using the QTR Create ICC
program to make the ICCs).  I have Photoshop curves posted that do the same
thing.  See http://home1.gte.net/res09aij/2000P-FS-curves.htm   I also have
a tutorial on adjusting them for new papers, etc.  See
http://home1.gte.net/res09aij/EZ_Adjustment_Curves.htm
Re: [Digital BW] Quadtine Rip Problem with Epson 2000P, Help Required
Hi Paul,
Thankyou for your help. Your method looks good but I have a good
supply of Original Epson cartridges for this printer which I would
like to utilise. The Quadtone Rip system is a great way to utilise
my supply of cartridges and get a cast free B&W print.
It would be great if I can get the profiles I need. Just one would
be a good start, say for Epson Archival Matte paper or any other
Epson matte paper.
Surely someone out there has had the same problem. I would
appreciate their help.
Best Wishes,
John
<paul.roark@v...> wrote:
> John,
there
Readme.htm
FS and
is use an
Create ICC
the same
also have
> Paul
> www.PaulRoark.com
2005-11-24 by jcrcameras
Hi
Further to my problem with QTR, the Epson 2000P printer and the lack
of curves, I have been experimenting today and I have found that I
can use QTR with my 2000P and get a good print.
I simply treated the image as usual in Photoshop to get the best on
screen representation of the scene, as if editing for a Photoshop
print, then I converted it to greyscale, then I went to Image >
Adjustments > Curves. Then I clicked on the curve line and put the
following values into the Input / Output boxes as follows:
Input             63
Output           128
This gave me a pale image on screen with blown out highlights. I
then saved this curve for future use. Your values may be a bit
different depending on your printer characteristis but it will do as
a trial and you can adjust the Input / Output values to your taste.
I then saved the image. I opened QTR and loaded the image. I chose
the Printer as Epson 2000P, set Printer Model to Quad 2000, chose
Resolution 1440 Super, chose Speed – better, and pressed print.
The image produced was free of casts and metamerism, but was not as
fine as an image produced by Photoshop in that the printer dots were
more noticable under a magnifier, were much like the grain one gets
with film and a wet print, but were not visible to the naked eye. It
seems that QTR was only using the black ink.
I am amazed that this simple method was not known, or not suggested
by the other group members. I dont see why this method will not work
with other printers for which profiles are not included in the Rip
download.
Best Wishes,
John
