UT2 MIS inkset, R200, almost there...(Paul?)
2005-11-24 by mark_roth_505
I have been using the UT2 inkset in the R200. I've come up with a transfer curve to give an impressive result, except in the 65%-80% range, where the cyan (or light cyan) is too strong, giving a blue hue in that range. The rest is spot on, and I am most pleased with the (almost) results. I've tried everything in the Epson driver to compensate, have tried RGB curves, ATF curves, am stuck...am almost ready to start mixing inks, but that's a can of worms I'm sure I don't want to open. What kind of curve adjustments to neutralize/warm up this range and avoid the 'blue' look in that range? Thanks..Mark
