Epson C86 not up to paper handling of HPR 308gsm?
2005-11-23 by mkirschner
I've been happily using my C86 with EZ inks for a month or so now to
make outstanding prints on Hahnamuhle Photo Rag paper (the 308gsm
weight version).
I haven't made that many prints (maybe half a dozen on HPR itself -
but several times than on Epson Enhanced Matte) but recently the
printer has refused to feed the HPR paper, in spite of various
attempts at hand-holding and coaxing. Paper size and orientation
doesn't seem to matter - this happens with letter size paper down to
4x6. I checked the C86 spec, and apparently the max paper width spec'd
is .27 millimeter, which translates to about 260 gsm or so -
significantly less than the HPR's thickness.
Anyone have a suitable thinner substitute for HPR, other than the
thinner version of HPR itself (which might be a bit thin for my tastes
at 188 gsm, working from memory). I'm aware of Paul's and Clayton's
paper recommendations in general, but I'm curious about how others
might have worked around this particular issue.
Mitch Kirschner
Re: Epson C86 not up to paper handling of HPR 308gsm?
2005-11-23 by Clayton Jones
Hello Mitch,
>...printer has refused to feed the HPR paper,
I really like Red River's Dourian Art, which is pretty much identical
to PR (many suspect it is made by Hahnemuhle, they say it is made by a
German company).  It is 250 gsm and 2-sided as well.
As for feeding thicker papers, I find that if I bend a slight curl
into the leading edge of the paper, so that it's pointing into (or
toward) the thing that grabs it, I have more success.
Clayton
2005-11-24 by mkirschner
identical
a
Thanks for the tips, Clayton. Much appreciated. I tried curling the
paper one time per your suggestion, and it worked in terms of getting
the paper to feed and print. However, the print had some banding and
ink "spatter" near the leading edge. Whether there's any correlation
between that and the paper thickness, it's hard to say for certain but
to avoid potentially stressing the printer, I'm going to try the RRDA
and some other papers which stay within the C86's spec'd paper
thickness. Thanks again.
Mitch
