Bulk Inks required for UT-R2 (Question to Paul)
2005-12-09 by timeexposure
Hello, My UT-R2 are only there since yesterday that I'm starting to worry about the day they will be empty... What should I by? I've the full neutral set except Warm Yellow. If I understand well: Cyan & Magenta are the same density => Same ink here LC, LM, Y are the same density => LC,LM Same neutral Ink, Y warm ink So I could afford only buying: - a bottle of neutral Cyan (also used for Magenta position) - a bottle of neutral LC (also used for LM position) - a bottle of warm Yellow - a bottle of eboni black - a bottle of photo black Is it right ? On the site they have boottles for every position... Thanks for your help, François
