Setting brightness level on a mac display
2005-12-10 by marcsienicki
For those forum members using a mac; does it matter (in terms of WYSIWYG) where one places the monitor brightnes slider prior to profiling with iOne? Marc
2005-12-10 by Steve Kale
You should target the luminance according to the instructions in the i1 software.
> From: marcsienicki <marcsienicki@...> > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Date: Sat, 10 Dec 2005 15:32:11 -0000 > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Subject: [Digital BW] Setting brightness level on a mac display > > For those forum members using a mac; does it matter (in terms of WYSIWYG) > where one > places the monitor brightnes slider prior to profiling with iOne? > Marc > >
2005-12-13 by Phil Rose
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale <stevekale@b...> wrote: > > You should target the luminance according to the instructions in the i1 > software. I don't exactly know what i1 software "instructs" about the white luminance target values, but IMHO it's always best to target the luminance for what works _best_ for your environment rather than accept the calibration software's (possibly) arbitrary instructions. Here's what one reviewer (http://www.drycreekphoto.com/Learn/monitor_calibration_tools.htm) wrote about the i1 software's luminance setting procedure: "The recommended luminance levels are often too high; drop down to a more sensible value if necessary. A quibble is that the possible luminance values are given in steps of 10. This precludes selecting useful values for CRT monitors such as 85 or 95 cd/m^2. Avoid the "Easy" mode, as this chooses the default, overly bright settings." Keeping that in mind, if the goal is to have a setting that's "best for WYSIWYG", the luminance commonly needs to be aimed at a relatively low value; perhaps something not more than 140 cd/m2 (unless you work in an extremely brighly lit environment and evaluate your prints under _very_ bright lighting). What's best for you will require some trial (printing) and error (compare and readjust) to settle on a good luminance. Compared to good ol' CRTs, adjusting an LCD monitor to sufficiently low white luminance values can be a problem (depending on make and model). Phil > > > From: marcsienicki <marcsienicki@y...> > > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > > Date: Sat, 10 Dec 2005 15:32:11 -0000 > > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > > Subject: [Digital BW] Setting brightness level on a mac display > > > > For those forum members using a mac; does it matter (in terms of WYSIWYG)
> > where one > > places the monitor brightnes slider prior to profiling with iOne? > > Marc > > > > >
2005-12-13 by Steve Kale
I would not consider 140 low. It is also the luminance for an LCD recommended by GM. At a D50 white point, my Apple 23in HD Cinema Display barely pulls 115...WYSIWYG is much more related to white point than luminance. Either way, as a starting point GM probably know something about the issue and without a good reason for doing otherwise I would suggest following their advice.
> From: Phil Rose <pjrose@...> > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Date: Tue, 13 Dec 2005 05:04:50 -0000 > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Subject: Re: [Digital BW] Setting brightness level on a mac display > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale > <stevekale@b...> wrote: >> >> You should target the luminance according to the instructions in the i1 >> software. > > I don't exactly know what i1 software "instructs" about the white > luminance target values, but IMHO it's always best to target the > luminance for what works _best_ for your environment rather than > accept the calibration software's (possibly) arbitrary instructions. > Here's what one reviewer > (http://www.drycreekphoto.com/Learn/monitor_calibration_tools.htm) > wrote about the i1 software's luminance setting procedure: > > "The recommended luminance levels are often too high; drop down to a > more sensible value if necessary. A quibble is that the possible > luminance values are given in steps of 10. This precludes selecting > useful values for CRT monitors such as 85 or 95 cd/m^2. Avoid the > "Easy" mode, as this chooses the default, overly bright settings." > > Keeping that in mind, if the goal is to have a setting that's "best > for WYSIWYG", the luminance commonly needs to be aimed at a relatively > low value; perhaps something not more than 140 cd/m2 (unless you work > in an extremely brighly lit environment and evaluate your prints > under _very_ bright lighting). What's best for you will require some > trial (printing) and error (compare and readjust) to settle on a good > luminance. Compared to good ol' CRTs, adjusting an LCD monitor to > sufficiently low white luminance values can be a problem (depending on > make and model). > > Phil
2005-12-13 by Louis Dina
I'd agree with Phil's comments on luminance. I find 140 cd way too bright for my viewing environment (and probably most). I use 100 cd/m2 on my LCD at home. My goal is to have a pure white document in Photoshop match the brightness of a sheet of white paper displayed under my D50 viewing light. If they are very different, you will have a terrible time getting a good monitor to print match. It affects the perception of saturation, density and contrast. Just try viewing a print in brighter then darker light and see how it affects the result. Big difference. Another reason I choose a lower luminance level is that I work on both LCDs and CRTs. I typically set my CRT at 90-95 cd. Much brighter than that and you begin to radically shorten its useful life. So, I want them to be close for the sake of consistency. Most the commercial printers I work with shoot for a luminance level between 85 to 95 cd/m2. This seems to keep the contrast range on the display in line with the expected contrast of the printed piece. And yes, lower monitor brightness usually necessitates lower lighting levels in your workspace. Lou --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Phil Rose" <pjrose@f...> wrote: > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale > <stevekale@b...> wrote: > > > > You should target the luminance according to the instructions in the i1 > > software. > > I don't exactly know what i1 software "instructs" about the white > luminance target values, but IMHO it's always best to target the > luminance for what works _best_ for your environment rather than > accept the calibration software's (possibly) arbitrary instructions. > Here's what one reviewer > (http://www.drycreekphoto.com/Learn/monitor_calibration_tools.htm) > wrote about the i1 software's luminance setting procedure: > > "The recommended luminance levels are often too high; drop down to a > more sensible value if necessary. A quibble is that the possible > luminance values are given in steps of 10. This precludes selecting > useful values for CRT monitors such as 85 or 95 cd/m^2. Avoid the > "Easy" mode, as this chooses the default, overly bright settings." > > Keeping that in mind, if the goal is to have a setting that's "best > for WYSIWYG", the luminance commonly needs to be aimed at a relatively > low value; perhaps something not more than 140 cd/m2 (unless you work > in an extremely brighly lit environment and evaluate your prints > under _very_ bright lighting). What's best for you will require some > trial (printing) and error (compare and readjust) to settle on a good > luminance. Compared to good ol' CRTs, adjusting an LCD monitor to > sufficiently low white luminance values can be a problem (depending on > make and model). > > Phil > > > > > > > From: marcsienicki <marcsienicki@y...> > > > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > > > Date: Sat, 10 Dec 2005 15:32:11 -0000 > > > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > > > Subject: [Digital BW] Setting brightness level on a mac display > > > > > > For those forum members using a mac; does it matter (in terms of > WYSIWYG) > > > where one > > > places the monitor brightnes slider prior to profiling with iOne?
> > > Marc > > > > > > > > >
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale <stevekale@b...> wrote: > > I would not consider 140 low. Nor would I, which is why I stated "no higher than 140". You'd be amazed at how many LCD users insist that 300-350 cd/m2 is the _minimum_ white luminance that they could ever consider using (in discussions about printing WYSIWYG). They eventually "come around" to using values quite a bit lower, but only after much agonizing over prints that are "too dark". What motivated my comment was that your advice (i.e., to just follow "instructions in the i1 software") appeared a bit cavalier about the luminance level and carried, IMHO, an implication that it was of relatively minor importance. Sorry if I misinterpreted your comment. >At a D50 white point, my Apple 23in HD Cinema Display > barely pulls 115...WYSIWYG is much more related to white point than > luminance. But now you've _explicitly_ made what I believe to be a dubious assertion. Of course the white point is very important--all the more so if one is printing _only_ in B&W . However as a general aspect of WYSIWYG, the luminance level will certainly not be as minor a consideration as you seem to imply (again). > Either way, as a starting point GM probably know something about > the issue and without a good reason for doing otherwise I would >suggest following their advice. Ahh, "as a starting point", yes, now we can fully agree. Phil
