Medium format film
Medium format film
2005-12-14 by mtiktinsky
I have found that Fuji Neopan Acros (rated at 100, use at an IE of 50)
and Neopan 400 (rated and shot at an IE of 400), developed in pyro and
scanned in with a Minolta Dimage Multipro provides excellent results.
 The pyro stains the film so there is really no grain. I scan the
negatives as if they were color positives at 48 bits and 3200 dpi,
invert in photoshop to a positive and I get excellent results.  I am
shooting 6x6 format using the 120 film and have been very very very
happy with the results.
Mike
RE: [Digital BW] Medium format film
2005-12-14 by Paul Roark
Mike,
What pyro formula or source do you use?  I've been thinking a staining
developer may be the way to go also (when my Tech Pan runs out).  That
approach is sometimes said to work best with the old style films that had
more silver in them.  Do you find it works with Acros 100 as well as the
400?
Re: [Digital BW] Medium format film
2005-12-14 by scott_now_coming
Paul,
I used to use a pyro developer called (I think) PMK. It was sold by
Photographers Formulary.
This particular pyro develolper would last as long as it was a
liquid. No kidding!
Scott
<paul.roark@v...> wrote:
> Mike,
of 50)
pyro and
results.
am
very
staining
That
that had
as the
> 400?
> Paul
> www.PaulRoark.com
PMK Pyro - here's a link
http://www.photoformulary.com/DesktopModules/StoreProductDetails.aspx?
productID=89&tabid=9&tabindex=2&categoryid=31&selection=0&langID=0
> Mike,
of 50)
pyro and
results.
am
very
staining
That
that had
as the
> 400?
> Paul
> www.PaulRoark.com
Re: PMK Pyro - Also check Pyrocat-HD Formula
2005-12-14 by John Vitollo
Also check Pyrocat-HD Formula by Sandy King. I have not used it but it seems many switch to
it from PMK Pyro:
http://unblinkingeye.com/Articles/PCat/pcat.html
http://www.photo-supplies.com/pyrocat-hd.html
Re: [Digital BW] Re: PMK Pyro - Also check Pyrocat-HD Formula
2005-12-14 by Louis de Stoutz
I've been using PMK for years and I love it. The stock really keeps for
many years! Unfortunately on 35mm I almost always get streaks from the
perforation (not an issue on MF), something that has ruined many
pictures. I've tried different agitation schemes etc., to no avail.
because of that I looked recently into PyroCat. No streaks, but much
less staining. My tests (esp. concerning "scannability") haven't yet
gotten far enough for me to decide on which to continue.
Louis
> it from PMK Pyro:
2005-12-14 by Jonathan Borden
> 400?
I have used PMK for small format films (tank development) and ABC pyro for large format
films (tray development by inspection).
The 400 ASA T-grain type films (e.g. Delta 400) stain much better than the 100 ASA films
but the developer is fine for the slower films as well.
The approach of scanning as color may allow one to vary the effect of the stain vs. the
silver itself. In any case this is also the approach I've used.
Given the use of Photoshop it is less clear to me that any other characteristics, such as
acutance effects or the ability to tame blown out highlights, are as important as the fact
that the stock solutions last forever.
I still use ABC pyro for sheet film (8x10) development by inspection, but frankly for 35mm
I've recently switched over to shooting with Kodak UC 100 which allows me to modify the
color -> BW conversion process using adjustment layers.
Pyrocat-HD Formula
2005-12-15 by ccolbertbw
I have been using Pyrocat-HD for 4x5 for a couple of years. Works great with EFKE PL100.
Relatively thin negatives work best for scanning, of course.
Skies with the PL100/P-HD look a bit grainy, though not bad. Sharpness is great. I have
TMX and Agfa APX-100 negatives that scan with less grain. Not a side by side controlled
test of the same subject and conditions, but it doesn't seem to be a huge breakthrough for
scanning.
Costa
 --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Vitollo" <jvlist@c...> wrote:
switch to
> it from PMK Pyro:
RE: [Digital BW] Pyrocat-HD Formula
2005-12-15 by Timothy Atherton
> scanning.
Costa,
I jsut got some Pyrocat to try with PL100 (as well as maybe HP5 which is my
standard film) - what sort of times/speeds are you using
tim a
Re: Pyrocat-HD Formula
2005-12-15 by brouwerkent
Curious about this statement, Costa.  It has been my experience that I can get a much better
density range in scanning than I could ever get in a traditional silver darkroom.  I have many
negatives that always were a fight in  the darkroom ( to dense or too contrasty) , that scan
with full range and tonality and print easily via digital output.
Perhaps you are not getting the most out of your scanner.  Are you scanning in 16 bit?
Phil
2005-12-15 by Christopher Lovi
In response to your streaking issue.  Presoak your film with
distilled water for 30 seconds or so.  It will soften the emulsion
enough so when developeer rushes thru the sprocket holes development
is more even.
Hope this helps
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Louis de Stoutz
for
much
yet
> Louis
> > it from PMK Pyro:
