Windowsill Fade Test Update
2006-01-16 by Clayton Jones
Hello All, I got an email today inquiring about the latest results of my windowsill fade testing, and whether I am testing K3. It's been some months since my last report, so here is the latest (please pardon the dots, it's because of the HTML): Print.........Start Date....Elapsed Time...Visible Fading ---------------------------------------------------------- Eboni BO/EEM....11/05/03....26mos..10days......None UT7(Eboni)/EEM..02/08/05....11mos...7days......None K3/Merlin.......09/14/05.....4mos...1day.......None This is not a scientific test in any way, but is just FWIW. The fact that an unprotected BO print is getting some direct sunlight every day for over 2 years without any visible sign of fading may have some relative significance. The K3 hasn't been there long enough to deduce anything from it. The UT7 is about a year now. Just for reference, back in the days of pigments with small amounts of dye toners I saw fading as early as 4 months (Septone) and 6 months (early version of UT7). Dye inks would show fading in a few weeks. So this UT7 has now more than doubled the life of it's early version. Here is a description of my test environment for anyone unfamiliar with it (if you've read this before, nothing has changed). All test prints are unprotected, with a strip of 4-ply mat board taped across it in such a way as to cover a full range of tones. I periodically peek under the strips looking for any visible fading. The window is a large south facing picture window in south Florida (sub-tropical zone), covered by an awning, so it's mostly bright daylight without direct sunlight. However, during early morning and late afternoon, direct sun gets in under the east and west edges of the awning for a while. So there is some direct sun every day, but not the intense mid-day type. During the winter when the sun is lower, there is a larger % of time with direct sun (it gets under the awning for longer periods). In summer when the sun is higher the % of direct sun is lower, but because the days are longer there's a much longer period of bright daylight. So there's no way (without some sort of instrument I suppose) to know the actual amount of lumens or UV hitting the prints. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
