QTR partitioning with 2 same inks
2006-01-19 by Olivier
I'd like to make sure the wat you partition when 2 same inks in the
printer.
Say M and LC are loaded with the same ink. Once you have set M relative
to K, M Limit should read 50 and then LC "copy curve from" M Limit 100.
For instance :
M     Gray ink          Density 32   Limit   50
LC    Copy Curve from   Density M    Limit  100
Am I correct in this ?
Thanks.
Olivier
Re: [Digital BW] QTR partitioning with 2 same inks
2006-01-19 by Tom Husband
Sorry I don't have the answer for you but I'm curious why you would want two
positions with the same ink?
Tom
> printer.
> For instance :
> Thanks.
> Olivier
I simply have a Piezo kit installed on a 1280 (6 heads so 4 gray inks
in 6 bottles, consequently 2 pairs are the same)and I'd like all
bottles to be depleted simultaneously for 1/preventing head clogging
2/not ending up with 2 bottles uselessly full.
Olivier
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Tom Husband
want two
> Thanks,
> Tom
2006-01-19 by Howard Shaw
I'm not sure if I've understood you exactly but I think, if you had only
one ink and you would set the limit it to 50 then if you had two you
would set them both to 25 - half the limit each.
Howard
> printer.
> For instance :
> Thanks.
> Olivier
