Poor results from MIS EZ warm inks in Epson C86
2006-01-25 by aldurer2004
I've been using MIS Ebony for black only prints in the C86 and have
made some good prints.  Now trying the EZ warm inks the tone tends
towards a sort of pale sepia and to my eyes it has a slightly pinkish
tone.  I've experimented with the sliders and got the best results
from cyan +25 mag -18 yellow -18.  Another difference I've noticed is
that if the print is viewed at an angle the ink in the dark shadows
has a mottled effect, a slightly lighter shade lying on a darker shade
on the surface; this is not the case when the ebony ink is used alone
for BO.  I've been using Epson matt paper, nothing I've seen so far
from the EZ inks warrants anything more expensive.  Lots of people
seem to be very pleased with the Epson r2400, until I get mine I think
I will be return to BO printing; which I've read is supposed to be
more archival too.
RE: [Digital BW] Poor results from MIS EZ warm inks in Epson C86
2006-01-25 by Paul Roark
> ... EZ warm inks the tone tends towards a sort of pale sepia ...
I describe it at half way to sepia.  It is warm.  Whether it's the shade of
warmth that one likes is subjective.  I find it very close to classic tones
of older silver prints and platinum.  As the most stable ink, I think it's
an excellent ink for old photo reproductions and archiving.  "Carbon on
cotton" is still the digital archival image champ from what I can see.  But
I would not, of course, use Epson Enhanced Matte paper for this purpose.
> ... if the print is viewed at an angle the ink in the dark shadows
> has a mottled effect, ...
EEM and a number of other papers have this problem with lots of printers.
It's not unique to the C86.  Among other things, if a matte paper is
overloaded this can happen.  One of the reasons the R220 is at the top of my
list now is that it has a new paper type in the driver (Ultra Premium
Glossy) that optimizes the dmax on a number of papers.
> ... this is not the case when the ebony ink is used alone for BO.
My only objection to Eboni only printing is the roughness, which is a matter
of style.  I hope that some day the printers are good enough to deliver
Eboni only that is smooth.  At that point I will likely be a major fan of
the approach for matte papers.  In my next fade test I intend to have an
Eboni sample for comparison.  I expect it to be the standard against which
others should be measured.
Re: [Digital BW] Poor results from MIS EZ warm inks in Epson C86
shade of
classic tones
think it's
see.  But
purpose.
shadows
printers.
is
top of my
Premium
is a matter
deliver
fan of
have an
against which
> Paul
> www.PaulRoark.com
>Paul thanks for yours.  Are you saying that the EZ warm inks,
assuming cotton paper, are as archival as ebony black used alone?
I only use Epson matt for proofs.  My cotton paper currently is
Hahnemühle German Etching.  Yes, I agree using four carts makes for
smoother transitions but at A4 maximum size on the c86 I'm not so
sure BO suffers that much, of course because I now have the EZ inks
I'll continue to experiment.
> ... Are you saying that the EZ warm inks,
I think it would be close.  I'd rate Eboni only as probably having a slight
edge due to the dots being denser masses of carbon.  In general, in denser
masses of the pigments tend to protect each other from the elements (oxygen,
etc.) better.
> ... at A4 maximum size on the c86 I'm not so sure BO suffers that much ...
The best of the C86s can be very good, not doubt about it.  (My C86 bands,
however.) If I could get that quality from my 7500 with Eboni only, I might
use it for my large display prints.
2006-01-26 by aldurer2004
Paul, pleased to say getting good results now from the EZ warm inks
on Hahnemühle German Etching. Do you happen to know how difficult it
is filling the ez carts oneself?
a slight
in denser
elements (oxygen,
> etc.) better.
that much ...
C86 bands,
only, I might
> Paul
> www.PaulRoark.com
2006-01-27 by Paul Roark
It's easy.
I assume they are the same carts I fill all the time.  If there is a stopper
in the top of the reservoir, that is where you fill it.  I use a jeweler's
(very small) screwdriver to pry out the stopper.
MIS's instructions are here:  http://www.inksupply.com/c86_slc_refill.cfm
That picture is different than the half sponge-filled, half sponge-less
reservoir carts I use, but the basic refill instructions are the same.
I usually do not have to prime the cart when re-filling.  It's the initial
fill that requires that.
If you're using all warm ink, one 4 oz. bottle and one syringe (with needle)
will do.  (You might want a bottle of Eboni while you're at it.)  Of course,
you'll need a resetter for the chip.  As soon as one cart is nearly empty,
pull them all and refill all at once.
You'll get a little ink you your hands, but it's no big deal.  Work on an
easily-washable surface, near a sink and with paper towels handy.
Good luck.
RE: [Digital BW] R220 Question
> ...  Would Paul's ICC for ESG work for the semi-matte?
I don't know.  Since Premium Semimatte is not available in letter size, I
didn't test it.
It's easy to make ICCs using Roy's Create ICC.  Even a flatbed scanner will
work.  See http://home1.gte.net/res09aij/Making_B-W_ICCs.htm
> is the EZ ebony for the 220 the same as the EZ ebony for the C86?
Yes.
> Would Paul's ICC for Innova Smooth Cotton also be good on Fibaprint?
Probably.
R220 Question
2006-01-27 by Peter De Smidt
I recently picked up an R220 and am using the EZ inks. The prints are
definitely better than the ones I got on my c86, as there's
significantly less texture in the highlights.  Maybe I had a lemon C86.
Anyway, so far, I've been using Kirkland glossy, because I have a big
box of it, and soon I'll run some ESM.  Would Paul's ICC for ESG work
for the semi-matte?  I'd also like to try some matte papers. Question:
is the EZ ebony for the 220 the same as the EZ ebony for the C86? (I
have a bunch left from my c86).  Would Paul's ICC for Innova Smooth
2006-01-27 by Tom Baker
Paul  -
  How does on linerize before creating the ICC profile?
  Tom Baker
didn't test it.
Yes.
Probably.
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
  YAHOO! GROUPS LINKS
    Visit your group "DigitalBlackandWhiteThePrint" on the web.
Re: [Digital BW] R220 Question
2006-01-27 by vmixer42
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...>
> Probably.
Is this an ICC for Innova Smooth Cotton on the R220 using your workflow?  If so, where can
one download it?  I don't see it listed on http://home1.gte.net/res09aij/R220_UT-
R2_ICC_Download.html -- is there another place to download (even more) ICCs for popular
papers w/ the R220?  I have some of this paper lying around, never got great results w/ it
using the driver sliders (and I've no flatbed, or I'd have a go at it myself, honest!).
--Geoff
Tom,
I'm not sure this is what you were asking, but what is important is that the
same settings are used for the test strip that is used for linearizing and
when the ICC is used.  (The Print Preview color management for the first
test strip is set to No Color Management in CS2 or Same as Source in older
versions.  When the ICC is used it is "Let Photoshop Determine Colors.")  As
long as the driver settings are noted and consistent in this respect, the
driver settings can be whatever works best.  The settings I used for the
ICCs I made are listed at http://home1.gte.net/res09aij/R220_R2_Readme.htm .
> didn't test it.
> will
> Yes.
> Probably.
> Paul
> www.PaulRoark.com
> page.
> them short.
> the membership.
> and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> PRINT YAHOO GROUP.
>   YAHOO! GROUPS LINKS
> page.
> them short.
> the membership.
> section:
> PRINT YAHOO GROUP.
I'll post it soon.
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of
> vmixer42
> Sent: Thursday, January 26, 2006 10:13 PM
> Subject: Re: [Digital BW] R220 Question
> <paul.roark@v...>
> > Probably.
> If so, where can
> ICCs for popular
> great results w/ it
> myself, honest!).
> Cheers,
> --Geoff
> page.
> them short.
> the membership.
> section:
> PRINT YAHOO GROUP.
2006-01-27 by aldurer2004
Many thanks for taking the time and for all of your tips/help.
inks
difficult it
> It's easy.
a stopper
jeweler's
less
same.
initial
(with needle)
Of course,
nearly empty,
Work on an
> Good luck.
> Paul
> www.PaulRoark.com
Sticky valves on Epson 2400 carts?
2006-01-28 by Harry Saddler
Wondering if anyone's had this happen to them: I switched from a PK
to a previously used MK (matte black) cart on my 2400, and all the
dark areas on my next print came out cyan. Eventually, I removed the
MK cart, put it back in, and it now prints correctly. I'm assuming a
sticky valve. I keep the semi-used MK and PK carts in a ziploc bag
with the air pressed out while not in use.
Harry
