Profiles for Black & White
2006-02-02 by photoink2004
I am just now getting into B&W digital printing with the purchase of a 2400 - leaving the wet darkroom after 40 years. I use Monaco EZ Color to make custom profiles for color. Will the same profile also work for Black and White for a specific paper?
2006-02-03 by Steve Kale
No. Think of the Epson Adv B&W part of the driver as a completely different driver and so your colour profiles profile a completely different beast. Check out the ICC profiling part of Quadtone RIP. Works like a charm and provides full soft proofing. Only $50. http://www.quadtonerip.com/html/QTRoverview.html
> From: photoink2004 <jerry.robinson4@...> > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Date: Thu, 02 Feb 2006 21:08:10 -0000 > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Subject: [Digital BW] Profiles for Black & White > > I am just now getting into B&W digital printing with the purchase of a > 2400 - leaving the wet darkroom after 40 years. I use Monaco EZ Color > to make custom profiles for color. Will the same profile also work > for Black and White for a specific paper? >
2006-02-03 by CDTobie@aol.com
In a message dated 2/2/06 6:32:45 PM, jerry.robinson4@... writes: > I am just now getting into B&W digital printing with the purchase of a > 2400 - leaving the wet darkroom after 40 years. I use Monaco EZ Color > to make custom profiles for color. Will the same profile also work > for Black and White for a specific paper? > > To print black and white (or tinted B&W) images with color inks leaves you open to such issues as print color shifting under different viewing lights, and possible color shifting over time with differential fading. But if you can live with those issues, its necessary to use very precise ICC color profiles for your printing to avoid color tints showing in your grays. Scanner-built profiles are generally not acceptable for this demanding level of use, some form of spectro-based system is necessary. I'm getting ver acceptable B&W prints through PrintFIX PRO 225 patch profiles (though they are still subject to all the limitations noted above), and can see some slight improvement in B&W prints on certain difficult printer/ink combinations by moving up to the 729 patch target. Its still not a total solution for black and white; but then, it works on most any printer, and doesn't require a dedicated inkset or RIP, so the convenience is there, if not the stability. C. David Tobie Product Technology Manager ColorVision Business Unit Datacolor Inc. CDTobie@colorvision.com www.colorvision.com [Non-text portions of this message have been removed]
2006-02-03 by koloshor
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, CDTobie@... wrote: > > > In a message dated 2/2/06 6:32:45 PM, jerry.robinson4@... writes: > > > > I am just now getting into B&W digital printing with the purchase of a > > 2400 - leaving the wet darkroom after 40 years. I use Monaco EZ Color > > to make custom profiles for color. Will the same profile also work > > for Black and White for a specific paper? > > > > To print black and white (or tinted B&W) images with color inks leaves you > open to such issues as print color shifting under different viewing lights, and > possible color shifting over time with differential fading. Not really an issue on the 2400, which uses three dilutions of fairly neutral blacks (K, LK, and LLK) and has drivers set up to "lean" very heavily on the blacks when printing any neutral or near neutral color, even in its color modes. It uses only enough colored inks to "tint" the neutrals. Steve Kale's answer, about using the Epson ABW (advanced B&W) mode is the correct one. This mode makes neutral B&W easier than driving the printer's color mode through PhotoShop or other printing software.
In a message dated 2/3/06 2:47:07 PM, koloshor@... writes: > Not really an issue on the 2400, which uses three dilutions of fairly > neutral blacks (K, LK, and LLK) and has drivers set up to "lean" very > heavily on the blacks when printing any neutral or near neutral color, > even in its color modes. It uses only enough colored inks to "tint" > the neutrals. > I find that the 2400 and 4800 printers function pretty similarly to other Epsons in terms of printing B&W and tinted B&W through the color mode. My comments about using color profiles for B&W printing stand as stated... > > Steve Kale's answer, about using the Epson ABW (advanced B&W) mode is > the correct one. > Its the one that addresses the B&W mode. My comments address what the user asked: printing via ICC profiles and color mode. > This mode makes neutral B&W easier than driving the > printer's color mode through PhotoShop or other printing software. > > This mode prints non-previewed, trial and error black and white that has the advantage of minimal color shift under varying lighting conditions. C. David Tobie Product Technology Manager ColorVision Business Unit Datacolor Inc. CDTobie@... www.colorvision.com [Non-text portions of this message have been removed]
2006-02-03 by Clayton Jones
Hello Jerry, >I am just now getting into B&W digital printing with the purchase of a >2400 - leaving the wet darkroom after 40 years. I use Monaco EZ Color >to make custom profiles for color. Will the same profile also work >for Black and White for a specific paper? Since you have a 2400 you have more options than with older models. One important new ability is its ABW system which allows making BW prints without requiring profiles. If you have any interest in this approach the workflow is described in article #9 at the web link below. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
Use QTR Create ICC to generate an ICC profile (amended spec) and you get full and accurate soft proofing. Once you've got your preferred set of hues there's no trial and error.
> From: <CDTobie@...> > This mode prints non-previewed, trial and error black and white that has the > advantage of minimal color shift under varying lighting conditions. >
Jerry Since you have a profiling device it would be a shame not to also use it for ICC profiles that will work well with Adv B&W. Cheers Steve
> From: Clayton Jones <cj@...> > > Hello Jerry, > >> I am just now getting into B&W digital printing with the purchase of a >> 2400 - leaving the wet darkroom after 40 years. I use Monaco EZ Color >> to make custom profiles for color. Will the same profile also work >> for Black and White for a specific paper? > > Since you have a 2400 you have more options than with older models. > One important new ability is its ABW system which allows making BW > prints without requiring profiles. If you have any interest in this > approach the workflow is described in article #9 at the web link below.
2006-02-03 by Yoelis Diaz
Hello. I'm need to be a scientific? if I want to make artistic photo to show in gallery. After I read the e-mail from this group I'm scary. Ok my question is, If I buy epson 2400, Epson original ink and epson best photo paper I can make professional photos. I don't go to make commercial or wedding photos. I only go to print limeted edition ( only 2) one for sale and one for my self. I don't go to use thirt party ink. Thank you. --------------------------------- Brings words and photos together (easily) with PhotoMail - it's free and works with Yahoo! Mail. [Non-text portions of this message have been removed]
2006-02-04 by Clayton Jones
Hello Yoelis,
>(only 2) one for sale and one for my self. I don't go to use thirt
>party ink.
You do not need to be a scientist to make good BW prints with a 2400.
Please read article #9 at this web link, it shows an easy way
The 2400 is a wonderful printer and is easy to use.
Clayton
http://www.cjcom.net/digiprnarts.htm2006-02-04 by kenstrain2000
Of course not! Make beautiful art. Have fun. The science** is very helpful (to some) to aid reliable communication, where the art is not directly visible, but is optional in many other circumstances. Ken ** by which I mean methodical procedures communicated in such a way as to be reproducible by others --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Yoelis Diaz <yoelisd2003@...> wrote:
> > Hello. > I'm need to be a scientific?
2006-02-04 by Steve Kale
Yoelis The 2400 is a great printer (a Godsend in fact) and you will get great prints from it using Epson Adv B&W. Have fun Steve
> From: Yoelis Diaz <yoelisd2003@...> > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Date: Fri, 3 Feb 2006 14:43:59 -0800 (PST) > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Subject: [Digital BW] I'm need to be a scientific??. > > Hello. > I'm need to be a scientific? if I want to make artistic photo to show in > gallery. After I read the e-mail from this group I'm scary. Ok my question > is, If I buy epson 2400, Epson original ink and epson best photo paper I can > make professional photos. I don't go to make commercial or wedding photos. I > only go to print limeted edition ( only 2) one for sale and one for my self. > I don't go to use thirt party ink. > Thank you. > >
2006-02-04 by Yoelis Diaz
Is good to read this answer.
Thank you .
Clayton Jones <cj@...> wrote:
Hello Yoelis,
>party ink.
Clayton
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See Group Topic, Rules and Guidelines in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
SPONSORED LINKS
Digital wedding photography Learn digital photography Digital photography college Digital photography Digital photography web site Digital photography course
YAHOO! GROUPS LINKS
Visit your group "DigitalBlackandWhiteThePrint" on the web.
[Non-text portions of this message have been removed]2006-02-04 by Douglas meeuwsen
no need for science with the 2400. It works great on all epson premium papers. Very easy, with not a lot of test-printing. Just find a tone setting that you like in the "Advanced Black and white" (ABW) mode. there are four basic settings for "darkness". Just find the one that works best for your computer. Good luck...DM On Feb 3, 2006, at 2:43 PM, Yoelis Diaz wrote: > Hello. > I'm need to be a scientific? if I want to make artistic photo to > show in gallery. After I read the e-mail from this group I'm > scary. Ok my question is, If I buy epson 2400, Epson original ink > and epson best photo paper I can make professional photos. I don't > go to make commercial or wedding photos. I only go to print > limeted edition ( only 2) one for sale and one for my self. I don't > go to use thirt party ink. > Thank you. > > > --------------------------------- > Brings words and photos together (easily) with > PhotoMail - it's free and works with Yahoo! Mail. > > [Non-text portions of this message have been removed] > > > > > > > Please visit the Group Homepage to check the Files, and other > resources as they are often being updated. > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you > wish to unsubscribe, please edit your Membership preferences by > visiting this same page. > > Please follow these basic guidelines: > - As threads develop, trim off excess portions of earlier messages > to keep them short. > - Good manners are required at all time. No personal attacks or > flames. Hostile, aggressive or argumentative users may be removed > from the membership without notice. > - Keep your posts and threads related to the group topic of digital > B&W printing. Users who persistently make off-topic posts may be > removed from the membership. > - By posting on this forum you agree to abide by the group rules > and guidelines, and to abide by the actions and decisions of the > group Owner and Moderators. See �Group Topic, Rules and Guidelines� > in the Files section: > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE > PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE > �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL > NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, > CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, > DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER > INTANGIBLE LOSSES (EVEN IF THE �OWNER� AND �MODERATORS� OF DIGITAL > BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF > SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE > THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO > OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR > CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO > GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE > PRINT YAHOO GROUP. > > > > > SPONSORED LINKS > Digital wedding photography Learn digital photography Digital > photography college > Digital photography Digital photography web site Digital > photography course > > YAHOO! GROUPS LINKS > > Visit your group "DigitalBlackandWhiteThePrint" on the web. > > To unsubscribe from this group, send an email to: > DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > [Non-text portions of this message have been removed]
