Re: Air in hoses
Re: Air in hoses
2006-02-05 by Siobhan McClory
> There are 18 messages in this issue.
> Topics in this digest:
>       1. Re: Re: Problem with Epson 4000
>            From: Danny Twang <dannyt@...>
>       2. Re: Epson 4800 vs. 2400 question
>            From: "bwbonkers" <PeterDLevis@...>
>       3. Re: Do I need cleaning carts to switch inks on R220?
>            From: "Clayton Jones" <cj@...>
>       4. Re: Epson 4800 vs. 2400 question
>            From: "ginnylady33" <ginnylady33@...>
>       5. RE: Re: Problems using Eboni Black only on 1280 for B&W prints
>            From: "Paul Roark" <paul.roark@verizon.net>
>       6. Re: Problems using Eboni Black only on 1280 for B&W prints
>       7. Re: I'm need to be a scientific??.
>            From: Douglas meeuwsen <lipshurt@...>
>       8. Ultrachrome K3 vs Piezo neutral K7
>            From: "warinstephan" <stephanwarin@...>
>       9. Re: Re: Epson 4800 vs. 2400 question
>            From: Steve Kale <stevekale@...>
>      10. RE: Re: Problems using Eboni Black only on 1280 for B&W prints
>            From: "Paul Roark" <paul.roark@...>
>      11. Re: Re: I'm need to be a scientific??.
>            From: Yoelis Diaz <yoelisd2003@yahoo.com>
>      12. Re: Do I need cleaning carts to switch inks on R220?
>            From: "l33ry" <l33ry@...>
>      13. Re: Choosing a paper - Epson Ultrasmooth
>            From: "helen_bach2003" <helenbach@hotmail.com>
>      14. Re: Ultrachrome K3 vs Piezo neutral K7
>      15. Re: Epson 4800 vs. 2400 question
>      16. Re: Do I need cleaning carts to switch inks on R220?
>      17. Re: Epson 4800 vs. 2400 question
>      18. Re: Choosing a paper - Epson Ultrasmooth
> ________________________________________________________________________
> Message: 1
>    Date: Sat, 4 Feb 2006 15:59:33 +0100
> Subject: Re: Re: Problem with Epson 4000
> Thanks Greg, that did the trick!
> danny
>> Here might be the 4000 reset procedure:
>> http://www.inkjetart.com/forum/viewtopic.php?t=25&highlight=tank+reset
>> Scroll down to the bottom. The reset tool is safer since you can't
>> change the wrong thing and mess up your printer. I suggest having a
>> backup on hand as the chips do sometimes go bad during the reset.
> Message: 2
>    Date: Sat, 04 Feb 2006 15:04:10 -0000
> Subject: Re: Epson 4800 vs. 2400 question
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ginnylady33"
> <ginnylady33@...> wrote:
>> Thanks Peter for the useful advice.
>> 1-What is this "spectro. QTR ICC profile"? I've no idea. Could you
>> elaborate?
>> 2-Where is 'Clayton's website'?
>> Appreciate your help!
>> Ginny
> 1) I use a GretagMacbeth Eyeone spectrophotometer an expensive device
> used for measuring printed targets used in the creation of colour
> ICC  profiles. Roy Harrington QTR contains a program for making B&W
> ICC profiles if you have a measuring device. Its not neccessary just
> a refinement. You can still produce great B&W prints without creating
> a B&W profile. Have a look at Clayton's site.
> 2)Clayton's web site
> http://www.cjcom.net/digiprnarts.htm
> Peter.
> Message: 3
>    Date: Sat, 04 Feb 2006 15:15:25 -0000
> Subject: Re: Do I need cleaning carts to switch inks on R220?
> Hello Bob,
>> On the Epson R220, I intend to alternate using Epson color (dyebased)
>> and MIS R2 black and white pigment inks.
>> 1. Will this harm the printer?
>> 2. Is it OK to reinstall partially used cartridges?
>> 3. Do I need to purge with cleaning cartridges when switching ink
>> types, or is regular head-cleaning enough?
>> 4. Is it better to switch off with pigment color inks rather than dye
>> inks?
> Lots of people are using MIS pigment inks in these printers and
> reporting few if any clogs.  I didn't use cleaning carts with I put
> MIS in my R200, but I only did it one time.  I'm not sure if switching
> back and forth would increase chances of problems
> There is a lot of ink wastage due to cleaning cycles when inks are
> changed.  Since they are so inexpensive you might consider getting
> another printer, one for each ink, and not do any switching.  If you
> print a lot the ink savings will pay for it, plus save time and hassle.
> Regards,
> Clayton
> Info on black and white digital printing at
> Message: 4
>    Date: Sat, 04 Feb 2006 15:53:11 -0000
> Wow! Thanks Peter.
> What a wealth of information on Clayton's site! It is most informative.
>   Interesting that he is so pleased with Black Only printing. I assume
> that the 2400 can do BO printing.
>  Thanks again for your help!
>   Best
>   Ginny
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bwbonkers"
>>> elaborate?
>>> Ginny
>> Peter.
> Message: 5
>    Date: Sat, 04 Feb 2006 08:36:26 -0800
> Subject: RE: Re: Problems using Eboni Black only on 1280 for B&W prints
> Bob Frost wrote, in part:
>> ... As the 1280/90 was designed to work with DYE inks, it isn't the
>> least bit surprising that it won't work properly with pigment inks, as you
>> and others have found out...
> If the 1280-90 were the only samples of dye ink printers that we've used
> with pigments, I'd have to agree that maybe dye printers ought to be avoided
> for pigment ink use.  Some have great luck with the 1280-90, but my personal
> experience is that it is the least reliable Epson I've used with MIS inks.
> (Note that many of the 1280-90 problems relate to bad continuous flow
> systems and carts, but I'm excluding that discussion here.)
> The 1280-90 problems, however, may not be representative of all Epson dye
> printers.  My 3000 and 1160 lasted for years with pigments.  The 1160
> finally died, but the 3000 was sold as is probably still pumping pigs with
> good reliability.  The 1160 was also used by me as a test bed, where I even
> printed with water-color pigments.  So, it had a tough -- but long -- life.
> Many high-volume printers have used the 3000, 7000 and probably other dye
> printers for years with pigment inks.
> Now I'm using an R220 -- another printer designed for dyes -- with complete
> reliability with MIS pigments.
> So, while I can imagine that Epson might use finer screens or passages in
> the heads of printers designed for dyes as opposed to pigments, I suspect
> the problem may be more unique to the 1280-90 than an across the board
> problem with Epson dye printers.
> Of course the bottom line is that with the third party inks one can simply
> achieve better B&W and more lightfast prints for less money even if the
> printers don't last as long.  The ink price difference is so dramatic that
> it's cheaper to throw away a printer occasionally than pay Epson's prices.
> But for those using the 1280-90 with Eboni, be sure to rinse the dyes off
> the parking pad.  Eboni and dye are not compatible.  My experience with an
> old 1280 and Eboni was that I had to clean the surface of the head off
> routinely until I rinsed the dyes out of the parking pad.  Then the 1280
> worked for about a year without trouble.
> Paul
> www.PaulRoark.com
> Message: 6
>    Date: Sat, 04 Feb 2006 16:53:10 -0000
> Subject: Re: Problems using Eboni Black only on 1280 for B&W prints
> Dear Paul,
>  Thanks for the most informative response.
> I have decided to upgrade my B&W printing to a 2400. I've got the
> budget to do so.
> I wonder if you would compare the B&W print quality on the 2400 with
> the stock Epson inks vs. 3rd party. If 3rd party (MIS?) would be a
> significant upgrade, I'm wondering what set you recommend? (I had just
> read an article by Clayton Jones speaking of the virtues of black only
> printing.)
>  I'd really appreciate your expert input.
>   Thank you
>   Ginny
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
> inks, as you
> avoided
> personal
> inks.
> Epson dye
> pigs with
> I even
> -- life.
> other dye
> complete
> passages in
> suspect
> simply
> dramatic that
> prices.
> dyes off
> with an
>> Paul
>> www.PaulRoark.com
> Message: 7
>    Date: Sat, 4 Feb 2006 09:19:13 -0800
> Subject: Re: I'm need to be a scientific??.
> no need for science with the 2400. It works great on all epson
> premium papers. Very easy, with not a lot  of test-printing. Just
> find a tone setting that you like in the "Advanced Black and
> white" (ABW) mode. there are four basic settings for "darkness". Just
> find the one that works best for your computer. Good luck...DM
> On Feb 3, 2006, at 2:43 PM, Yoelis Diaz wrote:
>>   Hello.
>>   I'm need to be a scientific? if I want to make artistic photo to
>> show in gallery. After I read the   e-mail from this group I'm
>> scary. Ok my question is, If I buy epson 2400, Epson original ink
>> and epson best photo paper I can make professional photos. I don't
>> go to make commercial or wedding photos. I only  go to print
>> limeted edition ( only 2) one for sale and one for my self. I don't
>> go to use thirt party ink.
>> Thank you.
>> Brings words and photos together (easily) with
>> PhotoMail  - it's free and works with Yahoo! Mail.
>> Please visit the Group Homepage to check the Files, and other
>> resources as they are often being updated.
>> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
>> If you wish to receive no emails or just a daily digest, or you
>> wish to unsubscribe, please edit your Membership preferences by
>> visiting this same page.
>> Please follow these basic guidelines:
>> - As threads develop, trim off excess portions of earlier messages
>> to keep them short.
>> - Good manners are required at all time. No personal attacks or
>> flames. Hostile, aggressive or argumentative users may be removed
>> from the membership without notice.
>> - Keep your posts and threads related to the group topic of digital
>> B&W printing. Users who persistently make off-topic posts may be
>> removed from the membership.
>> - By posting on this forum you agree to abide by the group rules
>> and guidelines, and to abide by the actions and decisions of the
>> group Owner and Moderators. See „Group Topic, Rules and Guidelines‰
>> in the Files section:
>> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
>> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
>> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE
>> „OWNER‰ AND „MODERATORS‰ OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL
>> NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
>> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
>> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER
>> INTANGIBLE LOSSES (EVEN IF THE  „OWNER‰ AND „MODERATORS‰ OF DIGITAL
>> BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF
>> SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE
>> THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO
>> OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
>> CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO
>> GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
>> PRINT YAHOO GROUP.
>> SPONSORED LINKS
>> Digital wedding photography Learn digital photography Digital
>> photography college
>> Digital photography Digital photography web site Digital
>> photography course
>> YAHOO! GROUPS LINKS
>>  Visit your group "DigitalBlackandWhiteThePrint" on the web.
>>  To unsubscribe from this group, send an email to:
>>  DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
>>  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
> Message: 8
>    Date: Sat, 04 Feb 2006 17:23:10 -0000
>    From: "warinstephan" <stephanwarin@minitel.net>
> Subject: Ultrachrome K3 vs Piezo neutral K7
> Hi all,
> I'm very happy printing BW on HMLE Photorag with my HP 7960.
> I would like to go to to A3+ size.
> People seem not to be happy with 8750 on Hmle Photorag. I'm aware of
> the lasting issue.
> I'm hesitating between buying an Epson R1800 with Piezo Neutral K7
> and 2400 with Ultrachrome K3, and keep on printing on Hmle Photorag.
> Is piezo REALLY better than ultrachrome K3?
Hi all,
One of my printers that I have only had to use 1-2 times in the past 2
months has air  (about 2.50 inches)  in one of the lines.  While there
definitely is suction  still there, i.e. It moves forward during a cleaning
cycle, there is no nozzle check or it has been intermittent.   As it is a
relatively new CIS set-up I hate to  trash it and start over but is there
anyway of dealing with this.  (I have done fairly thorough nozzle cleanings
so feel sure that  the problem  is not a clogged  head but the result of the
air in the line. Does anyone have any ideas??  I would greatly appreciate
suggestions. The printer is a relatively new (has been kept has a back-up)
1160.  Thanks.  SIobhan
