Hello Eirik;
The Epson Carts and most after-market carts don't have channels etc
in the cart, just a plastic bag, which probably rquires les suctio9n
from the head to get the ink flowing. But it does sound like you
don't have enough suction, and there are two points where it can get
choked off. The first one is obvious-the head itself may be blocked
up. The second one is the filter in the little transparent 'damper'
that creates a reservoir of ink at the head.
Remedies, if either of these are the problem:
Get a copy of the 7500 manual on PDF for reference.
Move the head (printer off) to the center of the printer, and lay
down some paper towels under it.
Take the head cover off, & throw it in a drawer, you don't need it.
Remove the damper hold-down bar. This will give you access to the
individual dampers. Carefuly pry off the K damper, loosen the
plastic nut at the back and remove the damper from the line.
With a syringe and a bottom-fill adapter, gently push some cleaning
fluid or amonia-based window cleaner backwards through the damper
until the little circular filter looks fairly clean and will allow
easy passage of fluid.
Replace the damper on the line & tape it all out of the way.
Put a 6"length of small diameter plastic or rubber tubing on the end
of the bottom fill adapter, take up ssome cleaning fluid, and slip
the end of it onto the ink-port nipple on the head.
Gently push some cleaning fluid through the head. If you have
trouble doing so, push back-and-forth a few times, replacing the
dity fluid each time, until you can get a slow, steady flow through
the head. Remember, be gentle!
Once you get the head flowing well, leav cleaning fluid in it, and
go back to the damper.
Take the tube off the syringe, apply the bottom fill adapter to the
ink port on the damper, and pull ink through. Do it with the damper
in a vertical position, so you mostly fill the entire damper with
ink, you need the reserve in it.
When you have that right, put th damper back on th machine, put the
hold-down bar on, move the head back to the lock position.
Do at least 3 cleaning cycles before bothering with a nozzle test.
Everytime I've had to take dampers of mine, it took 5-6 cycles to
get the ink flowing again, so don't give up too quickly.
Hope this helps,
Steve Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Eirik Berger"
<eirik@...> wrote:
> Hello all.
> I have recently purchased MIS UT-ink (6 colors with Eboni black)
for my Epson Stylus Pro
> 7500. I bought it un 1 pint bottles since I have refillable
cartridges as those found on
> inkvillage.com:
> http://www.inkvillage.com/Refillable_Cartridges_Shop.htm
> When I bought the printer it was loaded with NanoChrome ink. It
worked at the sellers
> house, but after 1800 km in a car ( it might have been subzero
temperatures) the blavk ink
> just wont reach the paper. I have drained it for ink several
times, washed it and done init
> fills several times. It is not even black ink in the tubes going
from the cartridges to the
> head.
> I wondered if the problem could be that the Eboni black ink was
thicker than the
> NanoChrome black, but then I remembered that the Nanonchrome black
did not print
> either. In the cartridge there is a small "channel" at the bottom
were the ink flows before
> leaving the cartridge. Just before the outlet of the cartridge the
ink must climb an inch. It
> looks like the black ink never even manage this "climb". The black
ink does not seem to
> leave the cartridge at all!
> I know it is impossible to ask what is wrong, but can anyone lead
me in the right direction?
> Best regards,
> Eirik Berger
> Norway
