Removing ink from the Epson 4800 carts?
2006-02-24 by G Guhan Gunaratnam
Hello,
I would like to know if it is possible to remove ink from the 4800 carts,
and put them into R2400 cartridges (MIS spongless).  I'd also like to hear
any comments about those who've done this/planning on doing this.
Thanks!
gu
Re: Removing ink from the Epson 4800 carts?
2006-02-24 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, G Guhan Gunaratnam
<guruguhan@...> wrote:
> Hello,
carts,
hear
> Thanks!
> gu
Two ways, you can suck the ink out of the larger carts with a syringe
and a bottom fill adapter. Or you can cut the labels on the cart, pop
the plastic cover off, remove the ink bag and then cut one corner of
the bag. Drain into your bottles and enjoy. If you decide to buy a set
of carts for the 78/9800 instead (not sure if there is a price
difference, I would be interested in the empty carts (more directly the
case, pressure bladder, and valve assembly. You can contact me off list
if you end up with those 78/9800 carts.
