Re: [Digital BW] Digest Number 3788
2006-03-06 by wgh2005
Someone had asked about "oily looking" prints on EEM, using an Epson R1800
printer.
At 08:53 AM 3/6/2006, Olivier replied:
>This can only be fixed by
>setting in the driver another media type, spraying less ink or a
>linearization including ink limit setting. Not feasible on a 1800
My thought: this sounds like bronzing, which I think is what Olivier is
saying also. But I'm pretty sure that it could be remedied using the 1800.
The first thing I'd try is to use a different paper setting, such as
setting the printer driver to "PGPP" or even to "glossy film" and then
printing on EEM. That should help a lot.
Also - my 1800 doesn't do this when I print B&W. Does this bronzing also
occur when making color prints on EEM? Has the inkset been changed in order
to print the B&Ws (using an aftermarket K3 set or a home-grown K4 or
similar inkset for example)?. I would also consider the possibility that
the OP's sample of the R1800 needs adjusting. But first I'd try different
settings.
