Frank,
The last file was very small, 2Meg. I'm using Photoshop Elements 3.
I do have my OS and PE3 on the same hard drive and that could be a
contributing factor. I did a disk cleanup after the defrag. That
should have cleaned out the .tmp files. I will try freeing up more
space on the HD. Thanks.
Les
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Frank Kolwicz
<kolwicz@...> wrote:
> Les,
> If your print file sizes are anywhere near 100Meg, 2 Gig
(contiguous?)
> free disk space may simply not be enough and, if you are printing
from
> Photoshop, your computer may be using your primary drive for
Photoshop's
> "Scratch Disk" which, ideally, should be a dedicated partition on
a
> separate drive and as big as you can spare, but at least 5+ times
your
> largest file (including all layers etc.). Photoshop is a real
memory
> hog, there should be nothing competing with it, that you can
avoid.
> Printing will compete with Photoshop and, if you are trying to
work with
> Photoshop while printing, you may pull HDD and memory resources
from the
> printer - I don't know if there is a way to fix this, but you may
be
> able to make printing top priority at the expense of whatever else
is
> going on.
> Photoshop and your OS (Windows?) both need simultaneous access to
a hard
> disk for normal functions and they should not be the same HDD,
even if
> they use separate partitions. I think the ideal system setup is:
OS on
> one HD drive, Photoshop on another, scratch disk on another and OS
> "virtual memory" (WindowsXP nomenclature) on a fourth HDD. Such a
setup
> minimizes conflicting HDD accesses between OS and Photoshop (at
least in
> Windows - don't know about Macs).
> Frank
