can I switch printer ink positions?
2006-03-16 by deskofjk
I have a 1280 with stubborn clog on the light magenta jet.  I'm using UT2 ink and thought
I'd just go through life without yellow.  I probably don't yellow if I'm just printing neutral or
carbon prints right?  So, is there a way to reconfigure Paul's curves so that I
can put the "LM" ink in the yellow position and have the printer know where to find it?
You're thinking I should just get rid of the clog?  I've tried repeated flushes with MIS nozzle
fluid to no avail.  Maybe there's a better way.
Maybe there's a better printer.  I've gone through two 1280s now using MIS inks and it
seems I've used most of my ink on cleaning and related test prints...  I get beautiful prints
when it all works, but there must be a more MIS-friendly printer out there.
great thanks for any wisdom.  best, jonathan
Re: can I switch printer ink positions?
2006-03-16 by alanrew42
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "deskofjk"
<jkaplan@...> wrote:
<snip>
there.
This is worrying - are MIS inks prone to clogging? If so, I'd like to
know, because I'm thinking about putting MIS UT7 inks in my 2100.
Does anybody have other experience with MIS inks clogging in Epson
printers? Is it worse than the OEM inks in this respect? Are the clogs
harder to deal with?
TIA
Alan
2006-03-16 by Louis Dina
I have used UT7 inks in my 2200 and have NEVER had a clog.  It is
designed for pigment inks and works great with the UT7 inkset.
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "alanrew42"
> <jkaplan@> wrote:
> <snip>
out
> there.
to
clogs
> TIA
> Alan
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Louis Dina"
> Lou
Thanks for your first-hand experience report for this inkset.
Alan
RE: [Digital BW] can I switch printer ink positions?
2006-03-16 by Paul Roark
Re-configuring the curves is a problem, because the Red and Green curves
utilize the driver's built-in cross-overs between the light and dark inks.
I'd try to get rid of the clog by filling a cart with pure Windex (with
ammonia).  Don't leave it in the printer too long, as I've heard strong
ammonia can damage the heads.  However, it saved an old 2200 that I'm now
using that was what I thought was hopelessly clogged.
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of
> deskofjk
> Sent: Wednesday, March 15, 2006 10:38 PM
> Subject: [Digital BW] can I switch printer ink positions?
> ink and thought
> that I
> where to find it?
> inks and it
> there.
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
> and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
Re: [Digital BW] Re: can I switch printer ink positions?
2006-03-16 by Lee Hiers
I think the problem with clogging and the 1280 is folks running
pigment inks through an printer that's not designed for pigments.  I
use MIS inks in a C86 all the time with no clogs....the clogging is
the main reason I stayed away from the 1280 actually.
HTH,
Lee
Lee Hiers, AA4GA
"Have Dobro Will Travel"
2006-03-16 by Bob Marsolais
Alan,
I have been using a 1280 for a little over a year.  I switch one
printer between two different ink sets, UT2 and MISPRO.  I am using
MIS's spongeless carts.  All I do is switch carts and run one
cleaning cycle.  There is no trace of the previous ink after one
cleaning cycle.  I occasionally will have a clogged jet, but if it
is not cleared by a second cleaning cycle, I let the printer sit
overnight.  The clog is gone the next morning, indicating that it
was air in the print head that caused the problem.  This is not
uncommon when switching carts, although it does not happen that
often.
The only rule you must remember is that you can't let the printer
sit unused too long or you will have clogged jets.  My rule is that
I print at least once a week and I never turn the printer off.
There was one period of time where the printer sat for about two
months with no use.  I had a couple of clogged jets that were more
stubborn to clear, but they eventually did clear.  For those clogs,
I used a set of carts filled with non-foaming Windex.  I suppose
head cleaner from MIS or other suppliers would probably be a better
cleaning agent, but that is what I had on hand at the time and it
did the job.
I have a custom profile from Cathy's Profiles for the MISPRO
inks, Roy Harrington's QTR with Paul Roark's UT2, and Clayton Jones
BO approach for BO experimenting.  I could not be happier.  The test
prints I have done using test images off the web totally blow away
prints I've had done by a professional lab.  The test print images
are razor sharp and the B&W tonality and color accuracy is
fantastic.  A graphic artist friend of mine agrees.  I should also
mention that I have also gone through the head alignment procedure
in the Epson driver utilities to make sure the individual color jets
are optimally alligned, which may be the best kept secret.  I don't
think I've ever seen it mentioned on the forum, but I'd recommend
doing it if you're not satisfied with your printer's output.
The bottom line is that clogged jets are not a problem, only a
easily managed occasional nuisance.  It not the printer that limits
me, but this amateur's scanning and software tool skills!
That's my experience.
Bob
out
> there.
to
clogs
> TIA
> Alan
2006-03-16 by lulalake_1999
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Lee Hiers"
like to
> HTH,
> Lee
> Lee Hiers, AA4GA
Ditto Lee,
I remember when everyone on the Piezo site were tearing their hair
out about the clogs with the 1280 and Piezo inks. Consequentli I
shied away from Cone's inks and the 1280.
Nowadays things have gotten better with newer printers and better
inks. I just ordered a set of K7 for my 2200.
Cheers
Jules
