Will the 2200 running UT7 clog less than the 1280 running UT2?
I posted here a week or so ago with a clogged jet on my 1280. I
followed advice given and tried to clear it with windex, but after
several treatments couldn't improve it. I even took the head off and
squirted about three syringes of windex through it until I could get
a nice even spray of the stuff through the head. Put it all back and
the clog is still there. Then I tried leaving windex in the head for
8 hours or so and still, no improvement. I give up.
Now I'm eyeing my 2200, which has thus far enjoyed only Epson inks
and has rewarded me by never clogging in nearly two years. Am I
crazy to put UT7 in it? What about an Epson 4000? Do we think the
UT2 and UT7 inks will ultimately clog all of these printers?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Michaels"
<bob@...> wrote:
> MIS PRO color inks have become another reason for the 1280
continuing
> utility. They make the 1280 color output the equal of the more
recent
> models. And, no clog problems.
> I have an four plus year old 890 that mostly uses the MIS $5 cheap
> Chinese ink carts for general home office use although it get other
> inks including pigment from time to time. Absolutely reliable. I
think
> John Dean's observation about the dye ink flushing out the crud is
valid.
> Bob Michaels
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
> <paul.roark@> wrote:
> > > I think there is production variance in the 1280's...
> > That may be the case. I've thought perhaps the single color cart
> instead of
> > individual ones makes the spacing of the inlet pegs and cart
outlet
> ports
> > critical. That may, in turn, be more of a problem with third
party
> carts
> > that are not quite up to the Epson standards. But, I'm
speculating
> here.
> > > Lastly, 1280's only last a few years with pigments before they
develop
> > > a fatal problem with an increased tendency to clog...
> > That's probably the case. Here is where I wonder if some routine
> > Windex-in-cart maintenance would improve the situation.
> > I've been discussing the issue with MIS, and they think the 1280
is
> still a
> > viable platform. As such, I'm going to port the UT-3D to it
also.
> That may
> > fill the void of affordable 13" printers for the inkset. (The 3D
is
> running
> > on the 2200, but it seems to be getting hard to find and is much
more
> > expensive.)
> > Paul
> > www.PaulRoark.com
