2nd Desperation plea for help: MIS UT7,7600, Epson driver
2006-03-25 by lovelipp
For the last 2 weeks, I've been unable to solve this problem.
A couple of years ago, I made a set of sample prints of the same
image loading Paul Roark's curves for tones cool to sepia. The
prints are identical in all aspects except for the warm/cool color.
I've been using a PC, PS7, MIS U7 ink, a 7600 printer and the Epson
driver (HPR paper). The tones have always been identical to the first
set. The only difference between then and now is a new PC. When I
load curves for carbon or sepia, the prints are washed out, the light
tones disappear and the transitions are as jagged as they appear on
the screen (in green and blue). Paul did tell me to set to Adobe RGB
1998 to get rid of embedded profiles. I thought that did it, but I
still can't get a decent print. When I use the sliders, the prints
are good, but I can't get carbon or sepia.
I'm sure the problem is somewhere in the settings.
Under Edit, I check"color management OFF" or should it be "custom"?
Adobe RGB 1998
CMYK ":US web coated (SWOP)y2".
Gray gamma:" 2.2" Dot Gain: "20%:
Next: Under Color Management
RGB: Should it be OFF or convert to working RGB ?
CMYK: Off
Gray: Off
Conversion Options
Engine: Adobe (ACE)
Intent: Relative colormetric? Perceptual? Saturation? Which??
Should I check or uncheck Use black point compensation ?
Check or uncheck: Use dither(8-bit channel image?
Advanced Controls
Check or uncheck ? Desaturate monitor colors by 20%
Check or uncheck ? Blend RGB colors using gamma 2.2
Eternally grateful,
Arlene
arlenelove3@...
