will flatbeds surpass film scanners?
2006-03-29 by joshscapes
Hey all,
With the new epson v700 scanner out and reviews being very good about it, do you as a
knowledgable group think that flatbed scanners are going to be the best choice in the
future for scanning b&w negatives?  Conventional wisdom is that a dedicated film scanner
gives a better scan.  Is this wisdom changing?  I am excited about the possibility of a
flatbed doing a better job on b&w than a dedicated film scanner.  Your thoughts?
RE: [Digital BW] will flatbeds surpass film scanners?
2006-03-29 by Paul Roark
> ...  Conventional wisdom is that a dedicated film scanner
I'd have to see well controlled tests before I'd believe that a flatbed
could outperform a dedicated film scanner at about the same price point.
The only way I can see it making sense is if the increased volume of sales
of the flatbed lowered costs to the point where economies of scale
outweighed the inherent design advantages of the dedicated scanner.  Getting
more for the money, of course, is a real possibility.
I would not make a decision to buy such a scanner based on a subjective
review that did not have comparison resolution chart images.
Re: will flatbeds surpass film scanners?
2006-03-29 by scott_now_coming
I think it comes down to price vs quality: value.
For $800 for a scanner like the V-750 that will scan up to 8x10"
films up to 6400 dpi, how can you go wrong?
If you're only shooting roll film, you may want to go with a
dedicated film scanner like the Nikon ED-9000 or whatever.
But if one is shooting sheet film, I'd spring for the flatbed.
FWIW,
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "joshscapes"
<joshrandall@...> wrote:
> Hey all,
best choice in the
Your thoughts?
2006-03-30 by Greg
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "scott_now_coming"
All I know is that I'm in the market for a new flatbed scanner, and
I'm not doing anything until the v750 reviews come out, and maybe
some time after that. I still have to wonder if the 6400ppi is going
to be real or the normal over inflated value that Epson is pretty
well known for.
2006-03-30 by john dean
Greg,
Whether that file size is interpolated through magic or not, the real
issue is dynamic range, 4000 dpi is really enough for almost anything,
even most 35mm projects.
Epson, like Nikon and Imacon, most likely will lie about the dynamic
range numbers, but we won't really know until someone who is doing
really high-end scans does a range of comparison tests, from film that
isn't perfect, to see if this is really a new breed of flatbed. If
they somehow have managed to produce a really good dynamic range,
which I always expected to be on the horizon somewhere for flatbeds,
then fluid mounting under acetate with Kami fluid may well keep the
film flat and avoid the focus problems resulting from the film not
being completely flat in the standard Epson carrier. A poor dynamic
range produces noise in the shadows and often in the highlights as
well, and quite often a reduced color gamut. The Nikons are quite
noisy. I expect the Epson may at least equal that. They are all ccd
scanners, basically digital cameras, and the best flatbeds like Scitex
or Premier already pretty much equal the Imacon in dynamic range and
file size.
John
John
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Greg"
<dfaprinting@...> wrote:
> --- In
> well known for.
2006-03-30 by scott_now_coming
I don't think 6400 will turn out to be "real", but 2400 should
be "real" no problem.
A 4x5" sheet scanned at 2400 would provide a file large enough to
make a over 37 inches wide for the 4" side.
I've seen 40x50" prints from "old" digital technology that look great
(6x7 scans from a 2400 series Epson, printed on an Epson 9600).
So, the bottom line for me is, making a high quality 40x50" print
should be no problem.
I think the V-series will work out just fine. I'll comment here once
I get a hold of one and make some prints.
Scott
> --- In
going
> well known for.
Re: [Digital BW] Re: will flatbeds surpass film scanners?
2006-03-30 by jim kitchen
Dear Group,
Some incremental information for your files, and a couple
of pennies out of my pocket...
Apple¹s ³Image Capture² application will access the available
6400 DPI within an Epson 4990 Pro.
I use it periodically to see what the image is like, and the
image file is huge, where it tops out at 1.91+ Gb with a 4X5
black and white negative, scanned as a colour transparency
with the profile set to Adobe RGB 1998 8bit, which seems to
be the default profile setting for Apple¹s Image Capture.
The profile is also named Epson Perfection 4990.  There are
a number of other profiles available for the scan with Apple¹s
Image Capture application, but I have not tried any of them
to see what differences might exist.  Maybe I should. :)
The scan, on an older Mac of mine, takes approximately 25
minutes through a Firewire connection at this setting.
The image size becomes 1.27Gb at 16bit, when the colour
information is discarded and the image is inverted, for anyone
that might be interested, and approximately 650Mb for 8bit.
The image file is definitely a smoother image file compared
to my preliminary scan at 4800dpi, where the 4800dpi file
at 16bit is about 750mb.
I do not know if there are any limitations with respect to a
file size, such as scanning an 8X10 negative with Image
Capture, since I do not have one to scan.  That file would
be massive at 6400dpi.  Photoshop might choke on that one.
Personally, I do all of my final selective scanning on a Howtek
Drum Scanner.  An Epson flat bed scanner, at this time, can
not acquire the subtle detailed information buried in the
shadows and, or the highlights compared to a drum scanned
image.
A 4X5 negative in an Epson scanner does not produce a
quality image if the negative is bowed and, or if gravity
impacts the negative shape during a scan. The focused
sweet spot becomes extremely localized, and this issue
alone absolutely retards the effective use of a full negative.
I don¹t think Photoshop developed a filter to improve that fault.
A drum scanned image just rocks with any negative
because the negative is perfectly shaped against the drum,
floating on oil, and held in place by Mylar. The entire negative
is never out of focus.
It is unfortunate that the cost of a drum scanned image is so
exorbitant, depending on the final file size, but for myself, I
will make the choice to drum scan an image, once I decide
to select a specific image for exhibition, and only work with
that image file. I have two excellent sources for a drum
scanned image and their ability to produce a quality file
happens to be legendary.
But within a year or two, who knows. My drum scanning
sources might not be required.  The possibility of wet
mounting a negative on a flat bed might change my view,
but for the moment, that science is outside my fence...
Epson, et al, are slowly acquiring a market share, dominated
by drum scanners, where Epson continually improves the
image quality with each new generation.  Are they yet? I
don¹t think so, but again that is just my own opinion, since I
only like the information I see from a drum scanned image.
If I owned a drum scanner within a business, I would be
spooked by any reduction in business.  It will happen.
That said, and for the moment, my comfort avenue is a
drum scanned image, knowing I have a great image file
to work with, and the opportunity to print a great image.
jim k
2006-03-30 by Ernst Dinkla
Greg wrote:
> --- In
> well known for.
I expect that the Epson V750-M will have a true resolution
somewhere between 3000 and 4000. probably closer to the 3000
side. That isn't much lower than the 3600-3800 of the Nikons.
The Dmax and dynamic range may proof to be equal to the Nikon
8000-9000, the older Epson models already came close in German
ISO tests. The tube light source may result in more flare +
noise, on the other hand the oversampling + the tube light
source may prove to be nicer for B&W grain. Signal/noise can
only be measured in a good ISO test and there's a relation
between S/N and available resolution / film size when printing
big sizes. Noise doesn't always show in the print.
The focus issue is one thing to check. With wet mounting you
can reasonably well keep the (larger) film flat and at the
right focus distance from scan to scan. That focus finding
should be better than the 3 choices Epson hardware gives.
There's something I worry about more, if the scanner has done
several scans and warmed up I would like to know what changed
in the focus distance. The former models had a plastic shell
and the engineering had the sensor, traction etc fastened to
the bottom on a metal plate. The glass is at the top of the
plastic shell. It wouldn't surprise me if the 8 cm height of
the shell gives a focus shift of 0.5 mm after 20 scans. The
V700 etc seems to have a metal shell which would make it
better. There are some other ways to compensate temperature
influences. Without active focusing this becomes a thing to
control. I have seen some neat designs where the sensor
carriage actually rides against the glass (springs for some
pressure)  to keep the distance equal to the original. That
was on a cheap reflective scanner.
Ernst
           Ernst Dinkla
www.pigment-print.com
(         unvollendet         )
Earnest,
Have you seen the link on this page yet?
http://groups.yahoo.com/group/WETMOUNTING/message/656
A lot of technical information that I think a lot of people here may
be interested in.
Most of it is too technical for me, but I like the section on films
asigning a ddi number and resoulution and what not.
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
<E.Dinkla@...> wrote:
> Greg wrote:
> > --- In
and
going
> > well known for.
> Ernst
>            Ernst Dinkla
> (         unvollendet         )
2006-03-30 by hogarth@snappydsl.net
scott_now_coming wrote:
> Earnest,
> be interested in.
> Scott
Sadly, it's a "members only" group, and I already belong to too many
groups. My sanity (such as it is) can't take any more. Guess I'll miss it.
Bruce Watson
Re: [Digital BW] will flatbeds surpass film scanners?
2006-03-30 by DaleH
>best choice in the
>Your thoughts?
With the dual lens Epson flatbeds the comparison with dedicated film
scanners like the Nikon 9000 gets more interesting. What it comes
down to is the CCD chip and lens choices and whether the focusing
distance required with flat beds places too great a compromise on the
lens choice to approach the quality of the dedicated film scanners.
It would be interesting to get a spec list of the lens and CCD
components used in scanners.
DaleH
> Earnest,
> be interested in.
> Scott
The link itself can't be put here or does it go to the
Wetmount files ?
I unsubscribed that list yesterday. It isn't healthy when
moderators launch mailing lists as part of their commercial
activities. Some can resist the desire to bend the
information, Julio isn't one that can. And I didn't find much
news either.
Ernst
           Ernst Dinkla
(         unvollendet         )
Sure, I understand that.
And it takes forever for a message to get posted. Really irritating.
Here the link to the article:
http://aic.stanford.edu/sg/emg/library/pdf/vitale/2006-01-vitale-
digital_image_file_formats.pdf
The info that interest me the most in this article started around
page 15 or so, fwiw.
Enjoy,
Scott
> > Earnest,
may
> > be interested in.
films
> > Scott
> Wetmount files ?
> news either.
> Ernst
>            Ernst Dinkla
> (         unvollendet         )
2006-03-31 by Ernst Dinkla
Interesting,
I had a discussion with Tim Vitale some days ago about the
quality of Imacons and Nikons. Though I still believe he is
underestimating the Nikons I probably wouldn't have replied on
his first message when I had seen this article :-)
Ernst
           Ernst Dinkla
(         unvollendet         )
2006-03-31 by Greg
> It would also be nice if Epson put active cooling on the CCD to
> decrease the noise, but I bet they won't. Even a big heat sink would
> help, but a peltier cooler would be really nice.
This post was made more than 24 hours ago!
2006-04-01 by scott_now_coming
Greg,
Shoot that question over to Earnest. Maybe he could figure out a system
as you described.
Nothing like doing a "mod" to improve what you have. :>)
Scott
2006-04-01 by Greg
--- In
> Greg,
system
> as you described.
We'll have to wait for it to arrive and see what it has. The 3200
could be modified if you really wanted to do the work, but that
machine didn't really deserve it.
Still can't believe that it took over 24 hours for that message to
arrive.
2006-04-01 by Ernst Dinkla
Did Epson add Peltier elements in between :-)
Greg, it will be difficult to get any cooling on the sensor.
The sensor carriage (sensor, lenses, mirrors) has to cross the
length of the scanner. Any cooling system will add weight and
has to dissipate the heat somewhere outside the  shell of the
scanner. That's easier to implant on a fixed sensor + lens
system like the Imacon (some have it) or the Nikons (don't
have it). A silver bucket against the sensor where you drop a
lump of ice in per hour may be the only practical solution.
That model will carry the ddICE sticker.
Ernst
           Ernst Dinkla
(         unvollendet         )
It was interesting to see that the new Silverfast
multi-sampling feature gave the highest gain of Dmax with the
3200 (of all the Epsons). Lasersoft pages. The sensor well
size must suit the 3200 limited resolution better than on the
newer models including the 4990.  So I'm quite happy with the
3200 with all the mods I added, resolution on 4x5 is here more
restricted by the Epson 10000 print output size. It will be
replaced by a V700 or V750 (which one depends on what Vincent
is able to squeeze out in quality from the last). I am not yet
impressed by the first picture of the Epson wet mount holder.
I think there's a good chance for a third party wet mount
holder if the design and package is better. That could suit
the V700 then as well.
Ernst
           Ernst Dinkla
(         unvollendet         )
2006-04-29 by Martin Sluka
> holder if the design and package is better.That could suit
There are antireflections layers on glasses, lenses, mirrors in V750.
Maybe there is the difference.
Martin Sluka
2006-04-29 by Ernst Dinkla
> Martin Sluka
Martin,
I know and this time I even believe that the V750-M is
different to the V700 on that aspect (and not just marketing
hype). The better light reflection of the mirrors is however
only translated in faster scanning speed, they claim more
light gets through so the stepper motor can run faster. The
less color fringing with the CCD lens coating may be the main
quality difference. At least I guess that color fringing is
what they see reduced. To test the differences between the
V700 and the V750 may require very good testing methods, film
in glassless carriers might be too inconsistent for the
differences in hardware.
There's also more software aboard the V750-M but I have most
of that already in alternative packages. Nevertheless I will
order the V750-M. Price at 809 Euro is too much though if
compared to the US package at 800$ that contains more (wet
mount carrier included).
Rafe has added new snippets to his scanner pages:
Epson V700 v. Epson 4990 v. Nikon LS-8000 (Same Negative)
http://www.terrapinphoto.com/jmdavis/
About 2/3 of the way down the page.
Ernst
           Ernst Dinkla
(         unvollendet         )
